Hard Starting IT200 - 1984
  • rossbotha@gmail.com
  • rossbotha@gmail.com's Avatar Topic Author
Hard Starting IT200 - 1984 was created by rossbotha@gmail.com
Hi, I battle to kick start my bike. It starts easily using a drilling machine on the rotor. What I've done.
  1. New carb. Cleaned it after installing the new Clarke tank.
  2. Rebore with new piston and rings. Compression 75psi.
  3. Ignition is HPI. The timing is correct. Good spark.
  4. Once running it idles well.
I don't know what else to do other than clean the jets again. The carb was overflowing, now that's fixed. Some debris in the seat.
Any suggestions?
20 Feb 2024 06:28 #1
Replied by pahiker on topic Hard Starting IT200 - 1984
Does this carb use a starting circuit and not a choke? If so, did you confirm the passages are clear after your carb was cleaned? Is it only difficult to start when cold? If so, try putting it in 2nd gear, engage the starting lever, rock it back and forth 10 times to pull in mixture then put it in neutral  and give it a good kick. My larger 2 strokes responded well, but you usually don't need to do this on a smaller bike.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
20 Feb 2024 07:21 #2
Replied by MarkT on topic Hard Starting IT200 - 1984
I find it remarkable that you are able to spin it at all with the spark plug installed, and even start it, with a drill motor.
20 Feb 2024 07:56 #3
Replied by darinm on topic Hard Starting IT200 - 1984
Did you verify the jet sizing on the new carb? They are probably the wrong size if it's a cheap Chinese replacement. I remember my IT200 having a choke and starting cold in 3-5 relatively easy kicks.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: MarkT, Ht1kid, pahiker
20 Feb 2024 13:19 #4
Replied by rossbotha@gmail.com on topic Hard Starting IT200 - 1984
It's a Mikuni carb. Original. I'll check the jet sizes.
21 Feb 2024 00:02 #5
The drill struggles to get it going. Not cordless drill. Once it gets over the compression stroke it spins.
21 Feb 2024 00:03 #6
Make sure when kicking you aren't twisting the throttle open. Opening the throttle makes the starting circuit ineffective. (You probably aren't touching the throttle when using the drill)
21 Feb 2024 11:30 #7
The jet sizes are as follows:
main jet 260.
Pilot jet 35.
According to the manual main jet #330. Pilot jet #55.
It starts so easily with the drill. Choke and no throttle.
22 Feb 2024 06:52 #8
It's easy to have a habit of twisting throttle while kicking without even realizing it which is why I mentioned it.
The two jets you mentioned are significantly different in your "new" carb, which doesn't make a lot of sense unless it's not actually new or not specifically for your bike?  In any case, there are more calibrated parts in the carb that work together as a system... venturi size,  needle and needle jet, and slide cutaway differences can make a difference in main and pilot jet requirements.  In other words, good idea to check all the calibrated parts, not just a couple of them.
22 Feb 2024 14:27 #9
Replied by Knutco11 on topic Hard Starting IT200 - 1984
Correct me if I'm wrong, but shouldn't that engine make at least 110 to 125 psi of compression? If so, I'd test with another compression tester. I've had certain compression testers read low like that on small engines. Other engines I've worked on were truly low, and would refuse to start unless I spun it up with a drill, or push started it. Does sound like compression is low to me.
The following user(s) Liked this Post: MACE6772, Schu
23 Feb 2024 13:22 #10
