1974 DT 250A
- Philturn
1974 DT 250A was created by Philturn
Hi, does anyone have the following information?
I'm after the Yamaha part number for a Clutch cable, and if possible, the inner and outer cable lengths.
I'm also trying to source a wiring diagram, preferably in colour, but a diagram with a note of the cable colours would work. Every wiring diagram I have found, makes no mention of cable colours ☹️
Hope someone can help.
Atb, Phil.
Atb, Phil.
04 Aug 2024 09:59
Replied by Gr8uncleal on topic 1974 DT 250A
Did you check out CMSNL and/or Partzilla? Link to CMSNL for clutch cable attached.
Yamaha DT250 1974 USA HANDLE - WIRE - buy original HANDLE - WIRE spares online (cmsnl.com)
If it is JUST wire colours vs function that you need, then any Yamaha wiring diagram of that era, and a few years later, will provide that info. As per the other manufacturers, virtually every colour was the same across the model range for a particular function - eg horn wires are one pink and one brown.
The following user(s) Liked this Post: Philturn
04 Aug 2024 11:14
- pahiker
Replied by pahiker on topic 1974 DT 250A
Partzilla shows 363-26335-03-00 as the clutch cable and it's in stock, so you should be able to get it from your local Yamaha dealer. Hopefully someone else can answer the rest of your questions.
www.partzilla.com/product/yamaha/363-263...75e961492a735516383b
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
04 Aug 2024 11:14
"Partzilla shows 363-26335-03-00 as the clutch cable and it's in stock, so you should be able to get it from your local Yamaha dealer. Hopefully someone else can answer the rest of your questions."
I think that Partzilla, unusually, are wrong. The cable for the 1974 DT250A and DT360A was a one year only part. However, if you are prepared to change the routing of the cable slightly, it can work.
04 Aug 2024 11:28
- pabdt
Replied by pabdt on topic 1974 DT 250A
I just rewired a 1974 DT360A using the 1975 DT400B COLOR wiring diagram from the Tech Library->Wiring Diagrams.
There are some differences I'll mention, but if you look over the years, most of the wiring diagrams are almost identical w/the 2 position switch.
One difference is brake light wire color. In the headlight bucket, the brake light is a G/Y wire. The schematic shows Y/W. This wire is routed to the rear brake light switch as a G/Y, connected together with a Y that supplies power directly to the brake light.
Obviously you have points. Guessing that is just a ground breaker loop to the coil.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
05 Aug 2024 23:20
- Philturn
Replied by Philturn on topic 1974 DT 250A
Hi, thank you for the reply and information. I'll download that wiring diagram, and add your notes to it.
Atb, Phil.
Atb, Phil.
06 Aug 2024 00:02
- Philturn
Hi all, I think I have found the correct clutch cable at "Yambits" in the UK. If it fits correctly, I will publish the inner and outer lengths, and part number.
Atb, Phil
Atb, Phil
06 Aug 2024 00:13
- Mungral
Replied by Mungral on topic 1974 DT 250A
2 years passed. Shall we assume it didn’t fit correctly? I bought a cable from Wemoto but its too short at 109mm inner; they now have one Slinky Glide cable reportedly 117.5mm. Will 8.5mm be enough of a difference I
13 Sep 2026 19:44
- Philturn
Hi, I forgot to post the update. The new cable fitted perfectly. The measurements you mentioned are probably Centimetres, not Millimetres......
I'll try and find the part number for the new cable.
13 Sep 2026 22:54
- Philturn
CLC100 is the part number for the clutch cable.
13 Sep 2026 23:38
