upgrade front shocks
Replied by MarkT on topic upgrade front shocks
Early bikes used regular old motor oil in the forks which is going to be far "thicker" than 10 weight fork oil. I like straight 30 weight since it's hot here. Probably won't solve the bottoming though.
You could try Race Tech for springs. Cannon Racecraft will make anything you want for springs. Also see notes from RT325 on spacers etc and sometimes manuals will have specs for spring free length so you can tell if yours collapsed.
If you're handy, cutting a few coils off the stock springs and adding a solid spacer to make up the difference will increase the spring rate for almost free... you have to be careful not to cut too much and get into "coil bind" RT325 mentioned.
The following user(s) Liked this Post: nhsteve, Ht1kid
26 Jun 2023 15:54
#11
- Visitor
Replied by on topic upgrade front shocks
Just find some plastic water pipe, same diameter as the springs, and make some simple pre-load spacers. Its possible to get damper rod forks, working far better, as outlined in my earlier post, but it's a fair amount of work, and may well mean getting springs custom-made, for your rider weight.
27 Jun 2023 01:58
#12
- nhsteve
Replied by nhsteve on topic upgrade front shocks
Racetech does make emulator and springs for the '74 DT360A, I do not see them for the 175. Rather than give an amount of oil per fork, they are using a distance from the top of the tube to the oil using a tool they have developed, which I have seen a MotionPro version of as well.
Anyway, more info is better?
RT - Digital Product Search (racetech.com)
04 Jul 2023 08:25
#13
- asco
Replied by asco on topic upgrade front shocks
Leading Link bikes have front shocks. About 4% total.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
04 Jul 2023 13:06
#14
