1975 DT175 Won't Start
  • Renegade578
  • Renegade578's Avatar Topic Author
Replied by Renegade578 on topic 1975 DT175 Won't Start
The seal is at least 1/16th out from the case, maybe even 3/32nds.
07 Dec 2022 08:56 #31
Replied by Ht1kid on topic 1975 DT175 Won't Start
How much thicker is it than your original one I use the IT 175 seals on my Ct1c like MarkT recommends because of the dual lip
07 Dec 2022 15:17 #32
Replied by MarkT on topic 1975 DT175 Won't Start
Both styles OEM seal are 8mm thick.
Might have broken a ring or sucked in a reed?
07 Dec 2022 19:45 #33
Replied by wfopete on topic 1975 DT175 Won't Start
I really like these older on/off road bikes (1978 DT175) but I tell you they were sure put together like crap. AFAIK there is no way to align the exhaust head pipe gasket to the cylinder or the pipe; you just eyeball it and hope it stays in place while the pipe get tightened down. A dab of grease will help but still, what a weak design.
08 Dec 2022 10:26 #34
 WFOPETE....  exhaust to cylinder gasket is a ring that fits solidly and securely into a recess machined into the cylinder.  Perfect alignment.   Maybe you still have an old gasket installed?
The following user(s) Liked this Post: AirborneSilva, Schu
08 Dec 2022 11:49 #35
Back to the original thread from the thread hijack...
Metal in the oil drained is the transmission/clutch. Not sure what scraping sound could be. Did engine still run? Was scraping while riding or when stopped or both?
08 Dec 2022 11:53 #36
  • Renegade578
The engine still runs. I will try to post a video tomorrow of what it sounds like. As soon as I installed the crank seal, I started hearing a squeak when turning it over. I thought the squeak went away when I ran it for 5-10 minutes while tuning the carb. When I rode it around the block it died and that’s when the rubbing sound started. The squeak is still there. I think I’m going to have to pull the head and inspect the rings and cylinder walls. I looked inside through the spark plug hole with an endoscope, but didn’t see anything obvious.
08 Dec 2022 18:38 #37
This is a wild guess do you think it’s the magneto scraping possibly your source or lightning coil video will be great do you have mechanic stethoscope to help find the problem
Last edit: 08 Dec 2022 23:14 by Ht1kid.
08 Dec 2022 23:04 #38
  • Renegade578
Here are 2 videos. One is me kicking it with the run switch off so you can hear the noises. The other is it actually running. The reason it's smoking so much is because I put some 2 stroke oil directly in the cylinder to lube it up.
www.youtube.com/shorts/c6FPOSq5rC0
www.youtube.com/shorts/0iVznSsdgjk
Last edit: 09 Dec 2022 08:09 by MarkT.
09 Dec 2022 07:38 #39
I'm not sure which or both crank seals were replaced but I wonder if you may have a clutch hub nut, primary gear nut or flywheel nut not fully seated. The sound of the condition isn't very clear in the video. Sounds like a "Whirring" noise which to me indicates a clutch basket/primary gear sound.
09 Dec 2022 07:44 #40
