1975 DT175 Stumbles above 3500rpm
- kwzl1
Replied by kwzl1 on topic 1975 DT175 Stumbles above 3500rpm
OK. I'll do that.
29 Jul 2021 12:23
#31
- kwzl1
I tried greasing the oring, but it didn't make a difference.
30 Jul 2021 12:58
#32
- kwzl1
I removed the silencer from the muffler, and it helped a little. They I tried loosening the exhaust pipe at the engine. Had a lot more power, and would rev to 6000rpm before it would stumble. So it looks that is at least part of the problem. (My apologies to the neighbor for all the noise without the muffler.)
So I have a few questions yet that I hope someone can answer:
1. Redline on the tach is 7500. Should it rev that high? I would think so, but it doesn't want to run above 6000.
2. What are my options for cleaning the exhaust? I have heard that the carbon deposits can be burned out, but I don't have a torch big enough for the job, and I can't build a fire outside (burning ban due to extreme fire danger and 100 degree heat). Is there some way to chemically clean it out that works?
Thanks for any suggestions.
30 Jul 2021 13:07
#33
Replied by RT325 on topic 1975 DT175 Stumbles above 3500rpm
Your options are limited if you can't burn it out. Look down the tail end where you removed the end muffler & see if there's an obvious restrictive build up visible & poke it out & shake it out. I put my end muffler in the enclosed log fire & does a good job. Any engineering shops around that could get away with smoking things up. Have you checked the cylinder port--exhaust port. Unlikely, but small motors ie small ports build up around the port edge & have seen little yamaha 80 YG1T almost blocked off after years of farm use.--as i say, unlikely but!!. Burn the tail muffler out too if you go to an engineering shop.
30 Jul 2021 15:22
#34
- kwzl1
I had the cylinder bored and cleaned it all up already, so no restriction in the exhaust port. I can see some carbon buildup inside both pieces of the exhaust, but nothing looks restricted. Still, I need to get it cleaned out somehow.
Thanks.
Thanks.
30 Jul 2021 17:55
#35
Replied by MarkT on topic 1975 DT175 Stumbles above 3500rpm
Did you put the piston in with the arrow on top towards the front of the engine (exhaust port) and the windows in the piston skirt on the intake side?
30 Jul 2021 19:56
#36
- kwzl1
Yeah, piston is installed correctly. Appreciate all the suggestions. I'm missing something, just not sure what else to check.
Going to try and get the exhaust system cleaned out next.
30 Jul 2021 21:03
#37
- Swoop56
Replied by Swoop56 on topic 1975 DT175 Stumbles above 3500rpm
Going back to the carb O ring you've already replaced .
Did you replace with the original Yamaha part or have you just sourced the O ring elsewhere ?
30 Jul 2021 21:54
#38
Oring is important for sure--but--Listening to the video, Just get that pipe sorted & report back. Might end up having to cut it open but unfortunate that no fires allowed to burn it out complete. Think you answered the question by releasing the pipe at the front & doubling the revs. Winter here for us. Stay safe.
- kwzl1
Got the oring from Yamaha dealer.
31 Jul 2021 13:42
#40
