1975 DT175 Stumbles above 3500rpm
  • kwzl1
  • kwzl1's Avatar Topic Author
Replied by kwzl1 on topic 1975 DT175 Stumbles above 3500rpm
It was at full throttle. That's all it will do.
26 Jul 2021 20:41 #21
  • kwzl1
thanks for the response. I will check out the tail pipe.
26 Jul 2021 20:43 #22
  • kwzl1
BTW, the weird video was taken while I was riding down the street with one hand on the throttle, holding my phone near the engine with the other hand in order to capture the sound. It just so happened I had the phone upside down. Should have just held  the camera with it pointing towards the engine so it would have been easier to see what was going on!
26 Jul 2021 20:50 #23
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic 1975 DT175 Stumbles above 3500rpm
Audio was more important & that was excellent thanks. I guess it was held wide open or something like it, as sounded constant. More open than the revs where its limit to anyway.
Just thinking, apart from what i've said in other posts, you could space the pipe back at the cylinder with a few washers between flange & cylinder on each stud to let it exhaust freely to a point but not get arrested for noise, Well, not a big lot of noise like if the exhaust was removed totally. First job still is remove tail muffler though as be surprised if its not in there.
Last edit: 27 Jul 2021 05:24 by RT325.
27 Jul 2021 05:15 #24
  • kwzl1
Thanks for your response. Yeah, it was taken with the throttle wide open.
I will check out the exhaust system this week, and hopefully resolve the problem.
I want to ride this thing!
The following user(s) Liked this Post: MarkT, Bigdog302, RT325
27 Jul 2021 09:07 #25
Replied by Bigdog302 on topic 1975 DT175 Stumbles above 3500rpm
Keep us posted!
Dave
Jesus is Lord!
27 Jul 2021 11:40 #26
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
piston in back to front--no, be all lean to the extreme not rich. ignore that.
27 Jul 2021 17:08 #27
Replied by MarkT on topic 1975 DT175 Stumbles above 3500rpm
I can't remember the everything that was done...  are you sure the o-ring on the bottom of the jet setter is sealing good to the float bowl?
I think 75 was the last year they used that system...  even though they didn't need it anymore.
27 Jul 2021 19:02 #28
  • kwzl1
I did replace the oring. When I put the bowl back on, it felt like it was sealing. Is there some way to test if it is sealing properly?
28 Jul 2021 20:37 #29
Replied by Mothersbaugh on topic 1975 DT175 Stumbles above 3500rpm
A little grease on the O-ring will help seat it where it needs to be to seal well, and it will help tearing the O-ring as well.
29 Jul 2021 06:08 #30
