1976 DT175 Condenser Relocation
- Mothersbaugh
Replied by Mothersbaugh on topic 1976 DT175 Condenser Relocation
The following user(s) Liked this Post: MarkT, Midlife Motor
22 Jun 2020 14:26
#11
- GJVGC
Replied by GJVGC on topic 1976 DT175 Condenser Relocation
Still running well with the relocated condenser?
Im ready to order one from autozone and do this to my bike.
24 Jun 2020 10:49
#12
- Midlife Motor
Replied by Midlife Motor on topic 1976 DT175 Condenser Relocation
Just got home as I rode the bike to work. Yes, it’s running like a champ! 40 plus miles on new set up and it hasn’t missed a spark fire once. I’m calling it
good.
good.
24 Jun 2020 17:54
#13
- GJVGC
Great to hear.
Im going to give it a shot in a few days
The following user(s) Liked this Post: Midlife Motor
24 Jun 2020 18:47
#14
Replied by MarkT on topic 1976 DT175 Condenser Relocation
I ran many, many miles with the condenser relocated to the ignition coil... did the stator part a little different... nothing wrong with the way it was done here though... never had a problem.
24 Jun 2020 20:02
#15
- Midlife Motor
If I had to do it again, I would have done it differently also. I would have run the three wires to be soldered on the stator under the stator plate to get them farther out of the way of the flywheel path.
24 Jun 2020 20:41
#16
What I used to do is run lengthen the wire from the stator coil and run it directly to the points. One wire to one wire connection. Then I'd also shorten and connect the wire to the coil to the points.
Points would have the two wires attached to the terminal with ring terminals... Sometimes both wires in one ring terminal... more often I'd use a ring terminal on each wire. Soldered and shrink tube on all connections.
Last time I did this was before digital cameras or the Internet was available... so sorry, no pictures...
24 Jun 2020 20:55
#17
- Wozzy
Replied by Wozzy on topic 1976 DT175 Condenser Relocation
Hi Midlife. New to site. I had to replace condensor and went like you under the tank. I'm not getting spark! On your pics you sliced into ignition coil and where did the other wire slice into? Is it the black wire from Stator?
Thanks for any help.
Wozzy
Wozzy
27 Dec 2021 05:32
#18
