Clutch Plate Parts Crossover
  • shaneoc91
  • shaneoc91's Avatar Topic Author
Clutch Plate Parts Crossover was created by shaneoc91
Hey all,
I've got a 78 DT125 that needs some new plates and friction disc's. I'm noticing that I can get kits with all plates and disc's for years on either side of mine, yet for some reason mine only appears as the OEM on partzilla. OEM shows 36X-16321-00-00 for the friction disc yet it appears to be identical to the 79-81 plates which i can get kits for. Does anyone have a parts match for a kit? Would like to save some cash on a kit rather than individual order of possible.
Thanks in advance!
10 Feb 2025 15:47 #1
Replied by 1975175B! on topic Clutch Plate Parts Crossover
Do you need the pressure plates? The friction plates are available on eBay.
Last edit: 17 Feb 2025 15:12 by 1975175B!.
17 Feb 2025 14:33 #2
Replied by MarkT on topic Clutch Plate Parts Crossover
1978 and 1979-81 both use the 36X friction discs.  125 has 5, 175 has taller clutch and uses 6.
Very common part used on a lot of models.  The thing to watch out for is up to 75 the frictions were 4mm thick and 76-81 they were 3mm thick
The following user(s) Liked this Post: Schu, Badrul
17 Feb 2025 15:43 #3
