Do you need a ground for a two prong flasher.
  • hcdiiiga
  • hcdiiiga's Avatar Topic Author
1973 DT3.  It seems like somewhere I read in a post that for a two prong flasher you don't need a ground and two prong flasher will work, Maybe I imagined this, but just two prongs, no place to put a ground. Will the two prong work?
19 Jun 2026 13:44 #1
Replied by goatboy56 on topic Do you need a ground for a two prong flasher.
Just put a Napa #535 2 prong in mine with no problems.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
19 Jun 2026 14:57 #2
Yes, 2 prong is correct and what you need unless you're using the original equipment flasher.
(Modern 3 prong has a second "output" wire and not a ground so you'd end up with a direct short if you connect the 3rd terminal of a modern flasher to ground.)
The following user(s) Liked this Post: DVM
19 Jun 2026 15:44 #3
  • hcdiiiga
Replied by hcdiiiga on topic Do you need a ground for a two prong flasher.
Thanks.
19 Jun 2026 16:16 #4
