Help!! Rt2 not running right.
- Oldskoole
Help!! Rt2 not running right. was created by Oldskoole
Good afternoon Yamaha gurus. I have a RT2. Bought it three or four years ago, and I have rode it around, but, it’s not running right. I think the correct saying is, it’s loading up. Before I started messing with the carburetor, I would ride it, and all I have to go on is watching YouTube videos of guys riding the same bikes and seeing what they sound like as they go through the gears, but it’s sounding like it’s getting too much gas. Now when I twist the throttle all the way it runs like a scalded ape. So I’ve asked on some forums on what to check. So, the first thing I got was the OEM O-ring and went in there and sure enough it was all dry and brittle. I replaced it put it all back together. Rode it still doing the same thing. Took the carburetor back off went through all the jets, made sure they was in good shape not stopped up and cleaned them blew them out with air put it back together and still running the same way. Took the carb back off and pulled the needle valve seat out, and there was a little piece of something down in there, it wasn’t from anything in the carburetor, but it wasn’t allowing that seat to go all the way down. Got it out put it back on, doing the same thing. Lowered the needle valve one notch, same thing. Went to the top notch and it seems to run a little better at a lower speeds, but still not running like it should. Some people have said I need to adjust the timing. The tech manual says pull the head off and use the dial indicator. I’m not the best mechanic in the world, but, there’s just nobody around where I live that works on these old bikes, So you have to make the choice to learn how to work on them. I know you always start with the simplest thing first. I swapped the spark plug wire and put it on a brand new spark plug, same thing. I’m just lost. Could y’all please give me a checklist to go down and start checking. And give me a list of any tools that I need to buy to work on them. I have Deets telephone number and I’m just hesitant on calling him and bothering him. I probably talked to him seven or eight years ago when I ordered a wiring harness from him and he told me that he and some buddies drove all the way to California from North Carolina on these things. That’s what I wanna do, I wanna ride this thing like it was 1972. They’re made for riding and not looking at. Please, point me in the right direction. Thanks in advance from South Arkansas!
19 Apr 2026 13:55
- Swoop56
Replied by Swoop56 on topic Help!! Rt2 not running right.
A worn Needle Jet , and maybe worn Needle too might well be the the source of your troubles .
The Needle Jet is hard to find these days , but does pop up on Ebay occassionally .
I'm pretty sure I have a spare NOS one buried away in my spare parts stash .
If you're interested PM me .
19 Apr 2026 14:03
- Oldskoole
Replied by Oldskoole on topic Help!! Rt2 not running right.
I’m no expert, but it looks brand new. No sign of any wear, and I took my magnifying app on my phone and looked it over. Do you think I need to get that, or a rebuild kit. You never know if someone has worked on it and put the wrong keys in there. But it starts easy (well at least
when you bump start it, cause it kicks back like a mule, even with the decompression lever on, when you kick it)and will idle all day long.
19 Apr 2026 14:25
Replied by RT325 on topic Help!! Rt2 not running right.
Not mistakenly leaving the choke open?, the fact that it gets past it & takes off makes me think along those lines. Blocked air jet leading to the needle jet could do similar. OEM Oring is a tight fit into the bowl so should be ok. If that leaks you wouldn't be taking off on full song it'd just stay limited rich. Is the needle clip held down by the spring plate not sitting on top of it?. As i think SWOOP said, worn needle jet & needle but eyeballing with it out of the carb wear or elongation should be visible if its running that bad. I always say exhaust, but not in this case if it revs out on open throttle. When you had the needle jet out--if you had it out--did it locate back down on to the pin at the bottom that guides its orientation. Slide guide pin not gone missing. Cutaway pointing back to the aircleaner.
19 Apr 2026 16:29
- Swoop56
I guess firstly with your carb , you need to determine if all the jets are correctly sized ,
and actually Mikuni components . Some previous owner may have replaced the brassware
with an aftermarket carb kit . Many people have experienced issues after a kit installation .
Needles are seldom close to the OEM parts , and the other jets are often hit and miss .
As for your kickback issue . The bleed port that the decompression valve opens up ,
can get blocked up with carbon over time , so when you think you're opening it up ,
in reality , the port may still effectively be closed .
19 Apr 2026 18:41
- Oldskoole
The chokes off, but that’s one thing I didn’t disassemble, was the plunger system. Needle and clip are in with the silver plate on top and the spring holding it in. I’m pretty sure all jets and passages are fully open. I had the needle jet out and inspected it, but I’m not sure when you say pin that guides it, are you talking about on the carb bowl that guides it in straight?
19 Apr 2026 20:30
True 'that'. It can get blocked all the way down to the exhaust outlet but must be cleaned out from bottom to top as can't get at the down bit from the top. Gotta take the decomp valve out to do all that & head off to remove decomp although might be a way if you removed parts to get a socket onto it--without looking--Na forget that way!!. Cut the timing back to 2.5mm btdc. Or just set points at 12 thou to try it although not accurate for timing without checking. My old dog starts easy with no decomp connected. Have a recent video if I can find it & I'm touching 80 so don't need kickbacks thanks lol. Found my shirt video. Nothing to see here realy. Might have a longer heavier kickstart on it off an xs650 but not sure without checking. but by memory it's only 3/4 on the shaft which I might end up regretting. Might be a short shaft. All mix n match stuff. youtube.com/shorts/I6ZMtvCIhWc?si=u76OiZKh1Xu2E5vh
- Oldskoole
Is there anyway of making sure the jets are the right ones. I know Partzilla stocks a lot of oem carb parts for my bike. Will a new mikuni vm32 work on this bike? I guess I can check the service manual and it will give me the jet sizes. I really appreciate you helping me.
19 Apr 2026 20:39
- Oldskoole
Now, is taking the head off the only way to properly adjust the timing. I really need to see it done, to be able to understand it, cause I’m a newbie. But like I said, there’s nobody around here works on those old bikes. If there was, I would gladly pay them to do my work. I ran across one video of an older gentleman working on a DT2, setting the timing with a dial indicator. And mine will let me kick it down slow like you did on that video but then when I get to the hard part and go just past that and then kick it, it kicks back like a mule. Some say that’s a sign of the timing being off. A lot of times I have to research when y’all talk in the technical aspect of fixing these things so I can understand what yall are talking about. But I’m not scared to try and to learn and buy whatever I need to work on these things. I appreciate all you mechanics that are willing to help us mechanic wannabes. My biggest thing about not jumping into this is I don’t have the proper place to disassemble an engine. Because I would have to disassemble it and line it up so when I got through, I just had to go backwards to put it back together.
19 Apr 2026 21:02
Think I mentioned closing through points to 12 thou. Just try it & can pretty much guarantee it'll help with the kick back & timing will be in the ball park. You can probably see that I get mine against compression. Not past compression & start the kick from as near to right up as I can get it. I've see people feel compression & let it go through then kick from there but that's no good as ya asking to get kicked back. If that youtube I put up you should be able to slow it right down to get a good look.
The following user(s) Liked this Post: Oldskoole
19 Apr 2026 21:58
