1972 Yamaha CT2 175 rebuild update - Battery drain
  • Gr8uncleal
  • Gr8uncleal's Avatar
Well done!
I assume that you know that the headlight and meter illumination lights only work with the engine running and the ignition switch in the second position round.
If you do want to run the headlight, then either fit a 6v voltage regulator or use a 12v headlight bulb!
Last edit: 06 Mar 2026 08:13 by Gr8uncleal.
06 Mar 2026 08:01 #11
Battery drain is often a bad rectifier if the wiring correction doesn't fix it.
06 Mar 2026 10:05 #12
