1972 CT2 175 Ring gap
  • 78dave
  • 78dave's Avatar Topic Author
1972 CT2 175 Ring gap was created by 78dave
So discovery is always interesting -I had little ping marks on the top of the top of the piston and on the head.  I think I know why - the tip of the ring was missing.  I ordered new rings but did not notice I had a wiseco piston and of course the yamaha ring are not correct.  I got a set of wiseco .50 rings that are correct but notice the ring gap is too tight.  That  might be why the old ring broke in the first place.  Anyway using the bore x ,004 I get a measurement that is too tight so I am heading the to the machine shop to grind back a little - SO MY QUESTION IS? - IS THE TOP RING THE SAME AS THE BOTTOM RING GAP?  I KNOW FOR SOME THEY DIFFER, BUT FOR A WISECO PISTON AND RING ARE THEY THE SAME.  as always thinks guys for all your help
04 Feb 2026 06:35 #1
Replied by pabdt on topic 1972 CT2 175 Ring gap
I probably had the same 0.5mm over wiseco piston in my 175. Does it have "CD" stamped on top? IE, "CD" rings. Mine were gapped ~0.012". Both of my rings, same gap. The engine had run for decades like this.
I question your bore/piston, setup though. usually the rings are good to go as packaged.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
04 Feb 2026 12:48 #2
  • 78dave
Replied by 78dave on topic 1972 CT2 175 Ring gap
Thank you for the response. The bike was run many years after the overbore. I received it from a friend after many years stored in the garage. I was close on the gap - My esto,ates had it at .0104 and that would not fit in the gap. I will grind back just a slight bit to make it meet the .004 x bore standard and ,005 x bore for the second ring per wiseco.
04 Feb 2026 13:07 #3
sounds like a winning solution. I'm waiting for my 175 cylinders to come back....can't wait to check mine after the bore.
1969 Yamaha CT1 175
1973 Yamaha DT3 250
1974 Yamaha DT125A
04 Feb 2026 17:37 #4
Replied by MarkT on topic 1972 CT2 175 Ring gap
Wiseco is a high performance and originally came with rings NEEDED to be filed.  Because that's the correct way to build an engine.
That's one of the main reasons they got the nickname "Seize-co". People would not check the ring gaps which would cause a seizure.  Some machine shops decided the problem was they needed a lot more clearance than Wiseco recommended.  Guess what?  A larger bore opens up the ring gap!  So they'd rattle like hell but ring gap was ok so it was thought the excessive bore clearance was needed.
It wasn't.  Wiseco learned their lesson eventually and supplied rings that usually didn't need filing.  But some shops still bore two strokes with too much clearance.
I never had a problem with a Wiseco, but in the early days, I never got a new set of rings that didn't need to be filed to get the end gap correct.  I saw a lot of seizures at the track and most people I spoke to afterwards had a blank stare when I mentioned checking the ring gap.  (I think it was Harry Klemm or Gerhard Klemm that clued me in on the need to check ring gap when I had my first cylinder bored for a Wiseco)
The following user(s) Liked this Post: Schu, Ht1kid, automan
04 Feb 2026 17:49 #5
  • 78dave
My bore was 2.6115" and I multiplied that by .004 for the top ring and .005 for the bottom ring. I needed .0104 so I only needed to file back a slight amount to get get clearance. The bottom was .013 so just a few thousandths more on that ring and i think I am good to go. But it had to be filed to spec for Wiseco.
04 Feb 2026 19:20 #6
I used "MC" pistons this time, apparently a Japan product. What do you think of those w/regard to quality and gap if info known?
1969 Yamaha CT1 175
1973 Yamaha DT3 250
1974 Yamaha DT125A
Last edit: 04 Feb 2026 19:22 by pabdt.
04 Feb 2026 19:22 #7
MC was an aftermarket reseller if I remember correctly and were often made by Art or one of the same manufacturers Yamaha used.  Modern Pro-X pistons are often reboxed OEM parts these days.
OEM Yamaha ring end gaps tend to be almost too big most of the time.
It's been a while since I built a high performance car engine but all the "racing" piston kits absolutely required the ring end gaps to be set by the builder.  I used to have a really cool tool that made it easy to file the gaps nice and square
Always a good idea to check gaps on any engine but OEM rings tend to not need filing in my experience.
04 Feb 2026 21:34 #8
  • 78dave
When I first ordered rings I did not pay attention to the piston being wiseco. I ordered the yamaha .5 rings and their gaps was fine. Had to send them back and the new wiseco ring have the same marking the old ones had n.50 Somore as I do the rebuild - Dale Sweger is doing my crank so once I have that I can get it all back together.
05 Feb 2026 05:56 #9
Replied by automan on topic 1972 CT2 175 Ring gap
.004 per inch is for water cooled 4 stroke engines.
Last edit: 05 Feb 2026 07:08 by automan.
05 Feb 2026 07:07 #10
