transmission compatibility 70/71 and 72
- Green53
transmission compatibility 70/71 and 72 was created by Green53
Hi, there is a '70/'71 engine/transmission for sale nearby, would any of the cases, transmission parts etc. be compatible with my 1972?
Thanks.
Thanks.
24 Nov 2025 11:08
- pabdt
Replied by pabdt on topic transmission compatibility 70/71 and 72
The "tech library" here has
parts lists
for those bikes. You could compare them. Also, partzilla does product fitment across the years for parts.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1973 Yamaha DT3 250
1974 Yamaha DT125A
The following user(s) Liked this Post: Schu, pahiker
24 Nov 2025 13:59
Replied by MarkT on topic transmission compatibility 70/71 and 72
The 1971 DT1E Service Manual in the Tech Library has a Service Bulletin in the back that describes the different gear design and interchange for the earlier models.
24 Nov 2025 17:28
Replied by RT325 on topic transmission compatibility 70/71 and 72
I'm late to the party as usual but according to partzilla & my own thinking back to the day. "70 & "71 have the early trans where the 4th 5th selector is part of the drum. I've mixed n matched everything possible over 50+ years but be very careful. The early trans cases don't make provision for the 4th 5th delector shaft as isn't necessary. As a complete set with drum & its selector it should swap in to your "72. Only other issue is the early ones has coarse tooth gears but might've gone to fine by "71. I used to blow 3rd gear big wheel to pieces on the early box but that was doing pretty hard out mx riding & clutchless changes up n down. Clutch--what's a clutch lol. "70 & "71 partzilla links below.
photos.app.goo.gl/bJRYMSpjE9VoaiFY6
www.partzilla.com/catalog/yamaha/motorcycle/1970/dt1c/shifter-a
www.partzilla.com/catalog/yamaha/motorcycle/1971/dt1e/shifter-a
- Green53
Replied by Green53 on topic transmission compatibility 70/71 and 72
Thanks.
29 Nov 2025 13:32
