Oil Pump
- Swoop56
Replied by Swoop56 on topic Oil Pump
Your pump is for a twin cylinder bike , so definitely not a RT2 unit . ( It has two outlet lines ) .
12 Jan 2025 19:22
#11
Replied by MarkT on topic Oil Pump
With dual outlet hoses, it's definitely not the correct pump.
12 Jan 2025 19:34
#12
- DLongRT1/360
Replied by DLongRT1/360 on topic Oil Pump
Yes, the wrong pump for sure. I saw the exact pump for sale, and I think it goes to a 1972 Yamaha twin CS5 street bike. It was the pump I was given when I purchased my 360. Mistake or not it did not come off this bike. So now to find the correct pump, a rebuild and then install.
12 Jan 2025 20:14
#13
- DLongRT1/360
Thanks to all and 1971DT250 thanks for the recommendation on the tank painting. By the way does anyone know the color painted on the 1972 RT2 360 oil pumps?
My tank I just purchased.
12 Jan 2025 20:19
#14
Replied by RT325 on topic Oil Pump
Bike does look nice.
12 Jan 2025 22:04
#15
- Sneezles61
Replied by Sneezles61 on topic Oil Pump
I found duplicolor paint for autos claimed that silver birch was the match… and being a bit color blind, it sure look good when I repainted my oil tank on my RT2. And, I’m not too fussy a guy anyways.
13 Jan 2025 08:35
#16
- Swoop56
Looking at my parts books , The RT1 had two different pumps and two different drive shafts . The RT 2&3 shared the later type .
So be careful what you're buying . If you haven't already got the drive shaft , it might be wise to buy a pump and shaft complete .
The following user(s) Liked this Post: 1971DT250, swm, Ht1kid, Sneezles61
13 Jan 2025 11:21
#17
- 1971DT250
Replied by 1971DT250 on topic Oil Pump
Good catch on the dual outputs Swoop56.
Ditto on what you mention on the different pump part numbers. And there are many misidentified pumps (as well as other parts) on eBay. Some are honest mistakes due to confusion in the parts lists plus you never know what someone did before you got the bike or part.
I have some used pumps removed from 360s. Send me a private message with your address and I'll send them to you but you will need to rebuild one before you use it. And verify the mesh of the drive gears match.
13 Jan 2025 11:46
#18
- DLongRT1/360
Thanks again everyone and 1791DT250 I sent you a message with address. Thank you, Sir.
15 Jan 2025 06:00
#19
