CT2 signal lights
- djetmb
CT2 signal lights was created by djetmb
I've had lighting issues with my CT2, specifically the signals. I spent an afternoon removing each signal light, checking and cleaning all connections, grounds etc. I went through the harness and checked all the connectors.
The signals illuminate but don't flash with the engine off. They flash normally with the engine running. All the other lights and horn work fine.
The battery is new and fully charged.
I seem to recall that the signal issue was pretty normal for these old 6 volt systems.
Would fitting LED signal light bulbs help? I've read that the new LED bulbs are plug and play with no diodes etc.
I'm sure this has been covered and maybe someone could point me in the right direction.
Thanks to all and anyone who can help.
28 Jun 2024 14:29
Replied by RT325 on topic CT2 signal lights
Does the bulb wattage match the flasher relay.
Battery sound good so increase the bulb wattage.
If the relay says 8watt then go to 10watt.
They calculate the indicator light into it too on the dash or tacho so another 1.5 or 3 watts.
Not been given 12 volt bulbs by mistake.
28 Jun 2024 14:56
Replied by Ht1kid on topic CT2 signal lights
Member Skydancer46 did a good write up on how to do a LED conversion
28 Jun 2024 15:46
- djetmb
Replied by djetmb on topic CT2 signal lights
Thanks. The bulbs are 6V but I will double check the wattage.
Yambits have the correct bulbs so may include those in my upcoming order.
How would I find that LED write up?
29 Jun 2024 08:02
- Tinkicker
Replied by Tinkicker on topic CT2 signal lights
29 Jun 2024 09:04
- djetmb
Thanks for the link. Lots of great information.
29 Jun 2024 19:35
- SKYDANCER46
Replied by SKYDANCER46 on topic CT2 signal lights
Djetmb,
I just tried this kit on a 1983 XT200 the other day and it works great. Those early XT bikes have weak 6 volt set ups like the older Yamaha 2 stroke Enduros. 40 plus years takes it toll i guess even when all looks new.
- djetmb
Looks like LEDs are the way to go. I'll try your kit.
Many thanks.
Many thanks.
30 Jun 2024 08:48
- SKYDANCER46
You may only need to get a new negative ground 2 pin flasher relay and make sure your turn signals have 6v 21cp bulbs in them. Could be you just have a worn out or corroded stock flasher.
I get them from amazon for about $13.00.
30 Jun 2024 16:25
- djetmb
Just a follow up on the LED turn signals conversion and a big thanks to SKY DANCER 46 for the
article on how to do it.
I just completed the conversion and it works perfectly!! No issues.
And thanks to all forum members for their help.
29 Jul 2024 16:25
