rt2 rt3 common issues
  • Dillonhamm12$$
  • Dillonhamm12$$'s Avatar Topic Author
Replied by Dillonhamm12$$ on topic rt2 rt3 common issues
Yes I was referring to green loctite as for the puller I'm pretty sure I got it already probably the same one used for the other Enduros what I don't have is that fancy flywheel wrench iv always just used a rag between the crank and clutch gear but that wrench is allot better. I like the idea about the decompression in the spark plug hole quick and easy
22 Jun 2024 21:10 #11
Replied by RT325 on topic rt2 rt3 common issues
If you make a tool to hold the flywheel--or buy one, be sure it doesn't go too far in & catch the coils. I've seen damage done by owners not being aware. Sort of ruins ya day 'that'.
22 Jun 2024 23:41 #12
  • Dillonhamm12$$
Yes that would definitely ruin my day!! So second question are the bottom ends from the 250 compatible with the 360? I have a few of the smaller bike and from what I can see the bottom end seems to be the same case and transmission.
25 Jun 2024 03:04 #13
Cases may look the same & most everything will interchange. But 250 cases won't take a 360 cylinder. Stud spacing & case mouth is smaller. Crank is a shorter stroke on 250 even though both will fit either case. I've done all sorts of dodgy stuff swapping bits. Even used a 250 crank but i'd better not get into that tonight as you want a 360 not a 280.
Think we were talking de-compressor earlier. Today i cleaned out my blocked one, so the holes into the cylinder & down to the outlet i can confirm are 4mm although might go 4.2 but 4.5 won't. When i cleaned into the cylinder to size '4mm' i thought, well, the down hole has to be that size. But had to start smaller then go in steps to 4mm as was blocked solid & i was starting to think someone had driven something in there to block it off. Anyway i'm happy now. I'll start a post on that tomorrow with pics as decided to turn my racehorse into a pony--maybe a donkey, we'll see.
Last edit: 25 Jun 2024 05:09 by RT325.
25 Jun 2024 05:08 #14
