Headlight replacement
  • Stem
  • Stem's Avatar Topic Author
Headlight replacement was created by Stem
I have a rt2 and need a new headlight glass and bulb.  Is there a replacement / modification available?
02 May 2024 20:13 #1
Replied by pahiker on topic Headlight replacement
Do you want another sealed beam? If so, the below site has something that should work. I used a replacement 5.75 inch shell so I could run H4 bulbs and ditched the sealed beam.
normanlamps.com/4020.html
If you haven't already done so, install a voltage regulator per the below tech bulletin to prevent blown headlamp bulbs.
yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
The following user(s) Liked this Post: DVM, Sneezles61
03 May 2024 02:15 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Headlight replacement
03 May 2024 02:47 #3
Replied by MarkT on topic Headlight replacement
A standard 5 3/4" H4 reflector or sealed beam will fit just fine in the stock rim.  You simply use "W" clips from Yamaha or someplace like MikesXS.
The following user(s) Liked this Post: DVM, Ht1kid
03 May 2024 04:51 #4
  • Stem
Replied by Stem on topic Headlight replacement
Thanks much for the information.
03 May 2024 08:13 #5
