1972 Yamaha CT 2 Carburetor
- mpritch41
1972 Yamaha CT 2 Carburetor was created by mpritch41
So I need a new Carb for my CT 2...the OEM is a mikuni vm 24 sh. It has a short body in order to connect to the airbox.
the only flange fit carb I can find is a vm 20-273.
It is the exact size of the OEM except its a 20mm intake instead of 24mm.
Does anyone have any experience with this...will the bike run ok ?
Thanks,
mp
Thanks,
mp
- Bdee
Replied by Bdee on topic 1972 Yamaha CT 2 Carburetor
I haven't tried it but I have a vm20 in hand and I noticed that the ct's plastic intake manifold only covers the outer half of the o-ring gasket on the the carb. If I were to try I would use a thicker than stock o-ring.
13 Feb 2024 07:49
Replied by Gr8uncleal on topic 1972 Yamaha CT 2 Carburetor
Presumably you've tried fleabay? Used ones turn up regularly - sometimes advertised correctly, sometimes not!
13 Feb 2024 08:03
Replied by MarkT on topic 1972 Yamaha CT 2 Carburetor
What's wrong with your original carb?
13 Feb 2024 08:04
- darinm
Replied by darinm on topic 1972 Yamaha CT 2 Carburetor
Worst case I'd say get a spigot to flange mount adapter for a VM24 and use a uni filter on it. But like Mark hinted at, few oem carbs are beyond a basic cleaning.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
13 Feb 2024 20:19
Actually I was curious because of a few things... one is that the stock carbs are by far the easiest solution, two is that not too many are actually "bad", and three is that I have some miscellaneous AT/CT reed valve carb parts like bodies and float bowls so it might be possible to fix the original if something is broken.
The following user(s) Liked this Post: darinm, Ht1kid
14 Feb 2024 06:43
- mpritch41
Replied by mpritch41 on topic 1972 Yamaha CT 2 Carburetor
I bought a bike with no carburetor
15 Feb 2024 11:27
- mpritch41
This bike was bought without a carburetor.
15 Feb 2024 11:29
- mpritch41
I really wanted to put the OEM airbox back on it. This model carb was really short...66mm from front to back. most I've found are about 88 mm and they too long.
15 Feb 2024 11:32
Let me see if I have a complete one.
15 Feb 2024 11:39
