DT2 ignition
- Stevvo
DT2 ignition was created by Stevvo
Hi guys, what's the minimum amount of wiring I need connected to run my engine please?
09 Feb 2024 05:57
Replied by MarkT on topic DT2 ignition
One wire from points to ignition coil
The following user(s) Liked this Post: Stevvo
09 Feb 2024 06:43
- Stevvo
Replied by Stevvo on topic DT2 ignition
Thanks MarkT.
I need to rephrase my question. Engine is out and on the bench, how and what do I need to connect to show a spark when I spin it over, with no main loom involved? Assuming this can be done?
10 Feb 2024 09:40
Answer is still the same except you need to ground the frame of the ignition coil to the engine since the engine is on the bench.
10 Feb 2024 09:57
Oh and spark plug needs to be grounded to engine... same ground for everything.
Points wire out of stator is "officially" black/white but is often just solid black.
10 Feb 2024 10:08
Replied by RT325 on topic DT2 ignition
Or just remove coil off the frame & sit it on the head or clip an earth lead from coil to the head or anywhere on the motor to be sure.
10 Feb 2024 11:54
