CT3 main axle needle bearing part number?
- Bdee
CT3 main axle needle bearing part number? was created by Bdee
The parts list that is contained within the combined 71-73 100cc-175cc pdf, found in the download section here, lists three separate part numbers for the ref #32 in the diagram.
32 93315-31502-00 BEARING
32-1 93311-31507-00 BEARING, CYLINDER.#11 (DIA. 23MM)
32-2 93311-31567-00 BEARING, CYLINDRICAL 1
The first one can't be correct. Photographs show this to have a very thin race, unlike what is currently installed and the part number is the same as the drive axle needle bearing which does have a thin race.
The diameter of the hole is about 23mm so the second entry would be my guess but being new to this I thought I'd better ask.
thanks,
Rob
thanks,
Rob
29 Jan 2024 23:05
- Tinkicker
Replied by Tinkicker on topic CT3 main axle needle bearing part number?
Compare the specs of your bearing to a TA1512
30 Jan 2024 04:37
Replied by MarkT on topic CT3 main axle needle bearing part number?
What's the engine number?
30 Jan 2024 06:52
Nevermind. The bulletin I was thinking of doesn't have VIN's listed... There's a copy in the manual you're looking at on about page 150 of the PDF. Bulletin 336
Should be the 31507 like you said. Dimensions should be 15mm ID x 23mm OD x 12mm wide.
(The 31567 "might" be a new number for the 31507 but the pic on Partzilla seems to show a "TR1525" which is not correct as the specs I found look like it has a 25mm OD.)
The 31502 is for the output shaft on earlier models before they made the change to a bigger OD bearing somewhere in the CT2 model run.
Note that 31502 is still used for the needle bearing on the clutch shaft.
The following user(s) Liked this Post: Schu, Bdee
30 Jan 2024 07:32
- Bdee
Replied by Bdee on topic CT3 main axle needle bearing part number?
Thank you!
30 Jan 2024 09:43
