LT2 stator/flywheel
  • yamahahaha
  • yamahahaha's Avatar Topic Author
LT2 stator/flywheel was created by yamahahaha
Can a LT2 stator/flywheel be used on a HT1 ?
30 Dec 2023 16:08 #1
Replied by RT325 on topic LT2 stator/flywheel
I can only say probably, the LT2 being just a reed valve HT1 sort of.
It's when you get to mag model AT1's & CT1 that everything gets bigger.
So i'm no help sorry.
30 Dec 2023 16:48 #2
Replied by MarkT on topic LT2 stator/flywheel
Pretty sure the answer is yes and also pretty sure the HT/LT is the same size crank and stator as CT
30 Dec 2023 17:48 #3
LT2 has a 6304 on the mag side & CT2 has a 6205, therefore 125 also has a 6205.
Can't varify crank taper though.
Mag nuts are a different number but don't suppose that means a lot.
Not sure if i'm helping or hindering lol.
30 Dec 2023 18:49 #4
100 was built on the same basic starting size 125/175 center case casting with a shorter stroke crank and some other differences.  Easy swap as far as engine mounts are concerned.  I wanted to put a CT engine in my LT2 when I was a kid.
Partzilla shows same mag assembly for HT and LT
www.partzilla.com/product/yamaha/277-813...0358943085ae3514032a
Flywheel is the same for HT/LT/CT
www.partzilla.com/product/yamaha/315-813...0358943085ae3514032a
Source and lighting coils- same  (CT has a different lighting coil than HT/LT)
31 Dec 2023 05:24 #5
  • yamahahaha
Replied by yamahahaha on topic LT2 stator/flywheel
Thank you guys
31 Dec 2023 05:49 #6
Make that thankyou Mark!!.
I must learn or remember to scroll down on partzilla to see what fits what.
01 Jan 2024 01:34 #7
