First test ride - push home!
  • Fozzy500
  • Fozzy500's Avatar Topic Author
First test ride - push home! was created by Fozzy500
Hi All
Got my CT3 to the point where I was confident enough to test it on the road after having started and run it a dozen times in the garage.
imgur.com/sXGYJyU
I got a quarter of a mile before it spluttered and bucked then cut out. Subsequent kicking (the kick start!) would occasionally make it run for one or two seconds - so I pushed it home.
Stripped and cleaned carb again - no change.
Checked points (I hadn't looked closely at the ignition system before as it had always run so well) gap was a bit small but thanks to info gleaned from this site that wasn't necessarily a problem so continued to investigate. Bought a dial gauge, a flywheel puller and made a tool to hold the flywheel. Inspection showed the points and the condenser were new but I didn't trust the connection to the condenser - soldering was not good and insulation was burned back on the wires and it looked like the bare wires could touch or were touching the outside of the condenser. I got a new condenser, put a fibre washer on top and put shrink tubing over the top half of the condenser just leaving the contact exposed, then soldered slightly extended and newly insulated (shrink tube) wires.
Then checked and adjusted the timing.
After a couple of kicks she started - but only ran for a second - in other words still no good.
Next I decided to rule out the (new) spark plug (which was not sourced by me) so I swapped it with another new one which was in my CT1 project when I got it.
And that was the problem - now she runs perfectly - second test ride went without a hitch.
Yes I've had this new plug problem before with British bikes and I've read about it in this forum, plus when I change plugs I keep an old plug that I know works - but I still left it till last to check!!
The following user(s) Liked this Post: Ht1kid, Quartermaster35, Sneezles61, pahiker
22 Dec 2023 07:18 #1
Replied by Gr8uncleal on topic First test ride - push home!
Good news in the end.
Yes, a lot of crap repro/fake parts out there.
22 Dec 2023 07:57 #2
Replied by Tinkicker on topic First test ride - push home!
Glad you got it sorted.  Looks like a lovely bike.
22 Dec 2023 08:08 #3
Replied by msavitt on topic First test ride - push home!
good instincts re trying another "new" plug! might have avoided a kick-inducted heart attack, or pulled hammy!
22 Dec 2023 09:11 #4
Replied by RT325 on topic First test ride - push home!
Good she's up & running now. My first thought was flywheel key let go but obviously not that. Enjoy your ride. Old saying-- stay on the bus route for a ride home but you're all sorted now so that's good.
22 Dec 2023 12:33 #5
Replied by Ht1kid on topic First test ride - push home!
Congrats
beautiful bike now you get to enjoy it
22 Dec 2023 14:33 #6
Replied by LongStride on topic First test ride - push home!
Bike looks great! Congratulations!
2ET703 Central Texas
22 Dec 2023 16:12 #7
Replied by MACE6772 on topic First test ride - push home!
Been there - did this. Glad you stuck with it and found the solution. I now stock and carry spare new plugs and put a cylinder head temp gauge on all fresh rebuilds. Kick Ride Learn
22 Dec 2023 16:26 #8
Replied by Schu on topic First test ride - push home!
Nice Bike!
Have I mentioned how much I want a CT3?  They just never turn up in my price range.
23 Dec 2023 09:30 #9
  • Fozzy500
Replied by Fozzy500 on topic First test ride - push home!
Thanks for comments. Looking forward to getting it dirty!
26 Dec 2023 14:40 #10
