Stuck float bowl on RT3
  • pahiker
  • pahiker's Avatar Topic Author
Stuck float bowl on RT3 was created by pahiker
Float bowl is stuck, not yet ready to whack it with a rubber or plastic mallet. Info on another forum showed success with Kleenflow. Berryman  is available at a local Autozone and is listed as o ring safe. Any recommendations would be appreciated, TIA.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
15 Dec 2023 14:20 #1
Replied by 1971DT250 on topic Stuck float bowl on RT3
Proceed with caution. 50 year old carbs are brittle.
Soak it for awhile and pull it out and apply heat with a heat gun or hair dryer. Repeat as necessary. And replace the rubber and brass parts and gaskets while you're in there.
Also I use a # 260 main jet in mine.
15 Dec 2023 15:03 #2
And another suggestion. I presoak the gasket and slightly tighten the bowl screws. After a few miles I'll tighten them again. The span across the bowl is pretty wide for 4 screws. Easy to crack the tabs if you overtighten. Keep a rag under it for a few days.
15 Dec 2023 15:15 #3
Replied by RT325 on topic Stuck float bowl on RT3
Might be hanging on to the Oring.
Does it move off the gasket but feel rubbery.
Important little Oring 'that one' so replace it regardless.
Normaly it'd shrink & not hold on though so prob not that causing it.
15 Dec 2023 15:26 #4
  • pahiker
Replied by pahiker on topic Stuck float bowl on RT3
It's on rock solid, no movement at all.
1973 Yamaha RT3
2024 Suzuki DR650
15 Dec 2023 15:49 #5
Maybe i'm lucky but i just hit them with a plastic handle screw driver. Yours sounds bad though.
15 Dec 2023 15:56 #6
Replied by asco on topic Stuck float bowl on RT3
I have gently used a rubber mallet to get them loose. You need to lay it down on something solid, and tap on it on all four sides. Chances are it’s not hung up on the O-ring. Chances are good someone put some sort of adhesive on it. It would be just like hitting yourself on the fingernail or the toenail with a rubber mallet very late blows.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
15 Dec 2023 15:58 #7
  • pahiker
Success! Turned carb upside down, sprayed WD40 into the joint, then let it sit for an hour or two. Beat on it some more with a rubber mallet, then was wrestling with it and it popped off. Green nasty stuff inside the carb, off to get some Berryman to soak it in. Thanks to all for the suggestions, project RT3 is unstuck and moving foward
1973 Yamaha RT3
2024 Suzuki DR650
The following user(s) Liked this Post: RT325, Gr8uncleal, Ht1kid, Sneezles61
Last edit: 16 Dec 2023 13:52 by pahiker.
16 Dec 2023 13:51 #8
