Splitting cases CT 175
  • djetmb
  • djetmb's Avatar Topic Author
Splitting cases CT 175 was created by djetmb
I may have to split the cases on my CT 175 to fix an oil leak between the case halves. Someone used silicone instead of the proper case sealant. Do I need a case splitting tool?
I'm not planning to remove the crank if all looks well there. Any thoughts or advice? Thanks to all.
24 Nov 2023 11:41 #1
Replied by MarkT on topic Splitting cases CT 175
The crank should stay in the ignition side case...  a simple two bolt puller used on the clutch side of the crank will make it a lot easier.
The following user(s) Liked this Post: DVM, Ht1kid
24 Nov 2023 12:56 #2
  • djetmb
Replied by djetmb on topic Splitting cases CT 175
Question answered. Thanks alot.
25 Nov 2023 10:54 #3
