At2M Running! Clutch feels like it won’t disengage all the way
  • Thanney
  • Thanney's Avatar Topic Author
So I finally got the bike to turn on! It ran pretty well and I was able to ride it a bit. It died and when I tried to kick it back on it wouldn’t run. When pushing with the clutch engaged it feels sticky, almost like it’s not disengaging fully. I’ve messed with the clutch cable to no avail.
Any ideas on source? I’ve realized I’m running 10w40 instead of 10w30. Maybe the extra viscosity is causing my issue?
I haven’t messed with the clutch yet so it might be worn.
12 Nov 2023 13:59 #1
It's not the oil.  Could be a lot of things. When bikes sit a long time, the clutch plates can get stuck.  Sounds like yours isn't completely stuck though.  Could be adjustment or something too.  You should be able to start and run in neutral, clutch won't affect that.
The following user(s) Liked this Post: Thanney
12 Nov 2023 14:56 #2
Oh, and feeling some drag as you described could be completely normal.  It's not going to push as easy in gear with clutch pulled as it does in neutral.
12 Nov 2023 15:01 #3
  • Thanney
Ah I see. Thank you! Debating on if I should order a clutch replacement
12 Nov 2023 15:22 #4
