DT2 timing
- Stevvo
DT2 timing was created by Stevvo
I dont have a dial gauge but I do have timing disc. Can anybody tell me what 3.2mm BTDC is in degrees please? Failing that anyone know the eye to eye length of a standard conrod so I can work it out myself?
05 Nov 2023 08:51
Replied by MarkT on topic DT2 timing
It's been a while since I did the calculations but off the top of my head I remember the timing coming out right around 21 to 23 degrees BTDC for every model I calculated. (I assumed no piston pin offset, I'm not sure if Yamaha offset the pin)
The reed valve 250 should have a 125mm rod. Piston port 250 had 130mm rod.
The following user(s) Liked this Post: Ht1kid, Stevvo
05 Nov 2023 09:18
- Stevvo
Replied by Stevvo on topic DT2 timing
Thank you MarkT!
Replied by RT325 on topic DT2 timing
Be an interesting experiment to strobe it after, to see how close it 'actually fires' to your degree mark or however you mark it on the flywheel at 3.2btdc.
06 Nov 2023 03:20
Gvthnks, Piston movement is not a linear relationship to crank rotation, con rod angle (determined by con rod length) makes a difference. For example, with the crank rotated 90 degrees past TDC, the piston will be over half way down the bore due to the con rod angularity...
Near TDC, you need to rotate the crank more degrees to achieve the same vertical piston movement than you do when crank is near 90 past TDC.
www.torqsoft.net/piston-position.html
The following user(s) Liked this Post: swm, Schu, Ht1kid
08 Dec 2023 14:05
Getting too technical for me.
Think i'll just add a lever arm to the stator plate & spring loaded plate screws with a cable to a lever on the bars. Then move it to find its sweet spot of advance--just before it holes a piston!!. Similar to what my BSA B33 had with movable flat points cam plate. Then again Maybe Not!!.
09 Dec 2023 01:00
- gvthnks
Replied by gvthnks on topic DT2 timing
MarkT, thanks for the correction.
Apparently forgetting is a thing. I'm going to delete my post so no one gets confuserated by my math.
09 Dec 2023 04:56
