RT2 Clutch Ball
  • quidger
  • quidger's Avatar Topic Author
RT2 Clutch Ball was created by quidger
The clutch ball goes between the short plunger type rod behind the pressure plate and the longer clutch rod that goes through the axle and into the little spring clutch lever mechanism that also has a steel ball in it.
The long clutch rod is concave on one end. Does the concave end mate with the ball on the short plunger or the ball in the clutch mechanism?
It’s not really clear in the parts diagrams.
Any guidance would be appreciated.
25 Oct 2023 11:54 #1
Replied by RT325 on topic RT2 Clutch Ball
Does the concave look original because I don't think they were like that from new. If it were me I think I'd sit the detent against the small ball in the actuator. It'll be good. Big ball is 5/16--8mm but if you have the original then no worries. Just my opinion.
25 Oct 2023 12:58 #2
  • quidger
Replied by quidger on topic RT2 Clutch Ball
The big ball measures 8 mm. I’m sure the rod is original.
Probably wouldn’t make a big difference one way or another.
I appreciate your input.
25 Oct 2023 15:05 #3
