AT2M Starting Issues
  • PFC
  • PFC's Avatar Topic Author
AT2M Starting Issues was created by PFC
I am trying to get my AT2M to run again (it did previously - but not well)
I am looking for some troubleshooting tips in case I have missed something on my own.
what I have done:
plugs are new NGK and have spark and correct gap (data found here on this site) I have been working with the same 2 plugs for a while now - maybe I need try some new plugs ?????
main coil primary and secondary are in spec (data found here on this site)
I have not checked the source coil - but I am assuming it is OK since there is voltage to the main coil primary and the secondary is producing voltage for spark - I don't know what the source coil electrical rating is ?
plug wire and plug cap (new) in spec - this is a NGK cap with resistor - appears to be 5K
fuel is new high test with 32-1 pre mix
carburetor is new and is jetted just as the factory with exception to the jet needle - but i do have the correct size if needed.
crank seals replaced.
I believe timing is set as well as points; but while doing this there seems to be some crank bearing slop so i am sure this will affect the spark plug gap - which in affect I assume will cause a poor tune, but will it cause no run?
The cylinder is 1st over with new piston - rings - bearing - pin and clips so I am assuming the compression is OK - but I have not been able to read it - I will this week.
The bike will fire - typically it will fire after I clear the lower end and cylinder from being loaded up - the plugs are wet so i know it is getting fuel.
The bike has run - poorly for maybe a minute or 2 on several occasions but not recently.
I hope I am missing something stupid - maybe i should replace the points and condenser????
thanks for your comments!
04 Sep 2023 09:56 #1
Replied by MarkT on topic AT2M Starting Issues
My first thought is leaky petcock floods the engine while parked?
04 Sep 2023 10:13 #2
  • PFC
Replied by PFC on topic AT2M Starting Issues
thanks for the heads up - "turn the gas off"
in this case i am working with a service bottle of gas and it is shut off and disconnected from the bike after each service session -
i think when it loads up or floods if is me trying to get the bike started
04 Sep 2023 10:47 #3
Replied by Ht1kid on topic AT2M Starting Issues
Did you get a new Mikuni carb?
04 Sep 2023 12:54 #4
  • PFC
yes brand new - got it from Niche Cycles in the Tampa Bay area!
it is out of the box same jetting as the OEM with exception to the jet needle which I purchased the OEM size so I should be OEM set up
I have not opened the new carb up assuming it is set from the factory - but i bet someone is going to tell me to check it ;0)
04 Sep 2023 14:20 #5
Replied by RT325 on topic AT2M Starting Issues
Any chance of a video of it running for as long as possible. Video solves all--well, on a good day.
04 Sep 2023 15:14 #6
Replied by asco on topic AT2M Starting Issues
That motorcycle (AT2M) comes with a GYT Carburetor.
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
04 Sep 2023 16:18 #7
My guess is still that it's just flooded.
04 Sep 2023 17:01 #8
Replied by Lizeec on topic AT2M Starting Issues
If you bought the Mikuni from Niche Cycle you should be good as far as being a genuine Mikuni as they are a reputable dealer, but why do you think it is jetted properly for your AT2M? Mikuni carburetors are sold based on size & not specific application, the jetting specifications vary widely between an enduro and a mx bike. Case in point I recently bought a 38mm Mikuni from Niche Cycle and the stock main is a 340 and I think it came from Niche Cycle with a 220, the pilot calls for a 60 stock and I think it came with a 35 from Niche Cycle. I had the same experiences on jet sizes on a Mikuni I bought for a DT250 as well, the jets were only like $4-5 dollars each and I bought them at the same time I bought the carburetor. Maybe Niche Cycle will custom jet them before shipping? I have heard Sudco another reputable Mikuni dealer will custom jet them and perform other modifications prior to shipping?
Last edit: 04 Sep 2023 18:26 by Lizeec.
04 Sep 2023 18:14 #9
Replied by Sneezles61 on topic AT2M Starting Issues
Wasn’t it pointed out in a manual.. set at sea level?
Tooning should be preformed?
Sneezles61
04 Sep 2023 19:21 #10
