DT3 Seat Bracket Not Aligning With Seat Lever
  • Pete-RT1
  • Pete-RT1's Avatar Topic Author
  • Platinum Member
  • Platinum Member
TrailBoss the photo upload isn't working at the moment, easiest way is to drop your photos onto  imgur.com/  and use the link button or press Ctrl+k and post the link to your imgur photos.
Hope that makes sense.
Pete
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
30 Jul 2023 10:02 #1
Replied by 1971DT250 on topic DT3 Seat Bracket Not Aligning With Seat Lever
Are the other brackets for the hinge pins on the new seat pan in the same place/orientation as the old pan?
Also the rubber pad locations?
Last edit: 30 Jul 2023 12:05 by 1971DT250.
30 Jul 2023 12:05 #2
He put pictures in post#1 now
  Does the bracket not fit your seat bottom?
Last edit: 30 Jul 2023 16:55 by Ht1kid.
30 Jul 2023 16:53 #3
On the last picture, you’re going to have to elongate the left bolt hole on the latch side because it’s on there crooked. You have to make sure that you also have the hinges loose when you line everything up. You have to elongate one of the holes on the latch.
If you look at the picture, there’s more meat
on the left side underneath the bolt - than there is on the right side.
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 30 Jul 2023 19:46 by asco.
30 Jul 2023 19:44 #4
Replied by Dennis D on topic DT3 Seat Bracket Not Aligning With Seat Lever
I have some latches off both CT and DT bikes. I believe the CT ones are not as tall. Can send you a pic if you want me to.
31 Jul 2023 08:21 #5
Many seat restorations the rubber bumpers are not contacting the frame rails until a riders weigh is on the seat.
asco
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
01 Aug 2023 03:24 #6
If I could post the pictures here I would. I thought they were all the same also.
01 Aug 2023 11:01 #7
