DT3 Makes Cracking/Snapping Sound During Kickstarting, But Won't Start
  • Ht1kid
  • Ht1kid's Avatar Topic Author
Did you clean or replace your points and set the timing?
08 Jul 2023 15:36 #1
First thought & probably wrong, is, that it "sheared off the flywheel key" on its "full throttle" rev out.
Secondly "rebuilt" is a "very well" used word with a wide ranging meaning.
I'm just having visions of you push starting then hanging off the side like a flag in the wind stuck on full throttle.
Wish i knew how to use emoticons or smileys.
Hope you get it on the road to recovery without too much more hassle.
"Flywheel Key"---!!
The following user(s) Liked this Post: MarkT, msavitt
Last edit: 08 Jul 2023 16:01 by RT325.
08 Jul 2023 16:00 #2
when I was 10 my best pal and I stole sisters moped and did the push start waving flag demo in front of a squad car!
08 Jul 2023 17:58 #3
Check the head bolts make sure they’re not loose because crackling sounds sometimes means air escaping through the head gasket. Just put a socket on it and make sure it’s tight, spark plugs, etc..
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
08 Jul 2023 23:59 #4
Ahh, i was thinking you'd had the flywheel off.
But still could be that.
Need the proper puller but if it's slipped & taken the key the nut is likely 'less than tight'.
This type below but there will be cheaper version out there for sure. It's the most common mag puller out there i think, fitting most other brands of bike with similar mags.
yambits.co.uk/dt3-flywheel-puller-p-24058.html
09 Jul 2023 00:31 #5
  • Ht1kid
If it was mine I would clean the points and check the timing and a new gapped spark plug if it won’t start it’s probably something in the carb
09 Jul 2023 07:26 #6
  • Ht1kid
Ok good did you set the timing?
09 Jul 2023 14:18 #7
  • Ht1kid
Your timing could be off if you’re getting kickback. Do you have a dial indicator? If not you can check the points gap should be in the service manual
09 Jul 2023 15:25 #8
