CT3 No Clutch Engagement
Replied by RT325 on topic CT3 No Clutch Engagement
Ok, so CT3 with a plastic actuator worm, & worm had been turned out to re-grease & restarted on the wrong spiral setting the actuator to far over???.
Good she's sorted.
The following user(s) Liked this Post: Mitch_w
Last edit: 09 Jul 2023 20:04 by RT325.
29 Jun 2023 21:25 #11
Replied by userdakota on topic CT3 No Clutch Engagement
MarkT, Whoa, I put the disks in wrong?....check your service manual. 250/360 yes, 125/175 no, they are installed correctly. Friction goes in last.
Last edit: 09 Jul 2023 20:07 by userdakota.
09 Jul 2023 20:02 #12
Umm--ok thanks.
09 Jul 2023 20:06 #13
Replied by MarkT on topic CT3 No Clutch Engagement
Whatever you say Userdakota.
(Engineering Drawing in Service Manual is correct, my bet is you're looking at the incorrect "exploded parts diagram".)
09 Jul 2023 20:42 #14
Replied by tsmitty1958 on topic CT3 No Clutch Engagement
Hi Mark,
I'm having the same issue. I'm double checking on the friction plate installation (73 CT3). I also, put friction plate in last. Could that prevent the clutch from engaging?
Thanks,
Tsmitty
14 Mar 2026 12:26 #15
