Re:Building the AT2 sleeper hot rod
Replied by bluntz465 on topic Building the AT2 sleeper hot rod
Oh yea! looks great,was the engine hard to mount up?There are sooooo many silencers you can find if your not happy with yours.The only thing I see is you may look for a bit of mesh to mount a heat guard to it so it don't bite ya.Hows it run? :OnFire
1982 Yamaha IT465J
27 Aug 2015 18:53 #31
One other thing,you will need to work out some mounts for the pipe as well.Hopefully the pipe has a tab or two you can mount some rubber to,and a couple springs at the header so it can flex a bit. :Subscribe :Subscribe
1982 Yamaha IT465J
27 Aug 2015 19:05 #32
Replied by Bigdog302 on topic Building the AT2 sleeper hot rod
totally agree with Bluntz! how about some video of it running and riding? how does it run? :OnFire :Subscribe
Dave
Jesus is Lord!
Last edit: 27 Aug 2015 21:26 by Bigdog302.
27 Aug 2015 21:25 #33
  • dose
  • dose's Avatar Topic Author
Replied by dose on topic Building the AT2 sleeper hot rod
To answer some of the questions,
Yes I realize Its not a sleeper anymore but it actually isn't any louder than when I was running the sleeper pipe.
Maybe some high heat black on the pipe will make it blend in more
No heat shields needed because I was sure to tuck it in close were my leg is while riding and at a stop. It may be hard to tell from the angles of the pics but its under the seat and tank there.
I do have 2 springs at the head and have a mount at the back silencer, just need one in the middle where they connect to each other and that will help it look straighter
It runs good and is no doubt faster than the 175 I was running but I am still tuning the carb finding that perfect jetting. Jetting is tricky at 8000'
Also the engine isn't super fresh with big compression either and a top end and porting will be in its future
The pipe is off of the blaster and I only cut and turned it to fit but did not change the volume of the expansion chamber. I did shorten the straight part between the cone and the silencer but from what I've read that should not change its characteristics. It will eventually rust where I cut and welded so that is another reason I was thinking of painting black. Its a hard decision because the nickel plating looks pretty sweet.
Im running a 16t front from a 90s RT180 with the stock back gearing and 428 chain. seems to be pretty good but I will see when its running at its potential
72 AT-2 with some mods
02 Sep 2015 17:59 #34
Replied by Scootern29 on topic Building the AT2 sleeper hot rod
I like it a bunch. Good job. Leave the pipe chrome.
:likey
02 Sep 2015 18:42 #35
  • 's Avatar
  • Visitor
  • Visitor
Replied by on topic Building the AT2 sleeper hot rod
Awesome.......its about time someone put a cool motor in a AT/CT frame ! :OnFire :OnFire
Tell us more about the labor to do this ?
You have been awarded fabricator of the month !
02 Sep 2015 19:34 #36
Replied by MadJack on topic Building the AT2 sleeper hot rod
thanks enjoyed the thread.
03 Sep 2015 08:45 #37
  • dose
I could leave my pipe chrome if my shocks were grey with some dual rate red springs. Hint Hint :)
05 Sep 2015 09:46 #38
  • dose
Ive done quite a few engine swaps and this one was pretty easy
The rear blaster motor mount is the bolt that goes through the swingarm. Same size bolt on 72 AT and 2000 blaster
:likey
I just cut the middle area out of the square part of the frame where the swing arm bolt is and the motor went right in
I beefed it up on the backside to make up for the material removed from the front
with the swingarm bolt in it lined up the motor with the sprockets real good
the front mounts were good side to side but needed to be about 5/8" moved back
I cut them off and fabbed new ones so it would look cleaner than adding on or extentions
the wireing was much simpler on the blaster, I was able to mount the coil and cdi under the tank easily
The blaster handle bar switch had on/off for the engine and headlights off//hi/low plugged right in to my headlight with the same wire colors as the AT2
In earlyer post I said how I did the pipe and chain/sprockets
The following user(s) Liked this Post: Makotosun, bluntz465, Bigdog302
05 Sep 2015 10:17 #39
I am working on your shocks. Send me an email @ This email address is being protected from spambots. You need JavaScript enabled to view it. with your phone number. I want to talk with you on a couple of things.
The following user(s) Liked this Post: dose
08 Sep 2015 17:46 #40
