Front wheel bearings
  • principal282
  • principal282's Avatar Topic Author
Front wheel bearings was created by principal282
I thought I had lost the spacer flange. Turns out it was just riding on the spacer.
AM I DOING THIS RIGHT?
73 DT3
went right off parts diagram.
from left
43mm long spacer
dust seal
13 mm spacer
big oil seal
bearing
Flame spacer with flat side on right
51 mm spacer with hole closer to right side
then other bearing which is already in wheel
of course not pictured other oil seal
then hub with brakes
then washer
then castle nut
see drive.google.com/file/d/1_8AKPJsGLnRSryb...K6/view?usp=drivesdk
Last edit: 08 Jun 2023 09:13 by principal282. Reason: I’m a bozo
08 Jun 2023 09:07 #1
  • principal282
Replied by principal282 on topic Front wheel bearings
I got it!!
The following user(s) Liked this Post: MarkT, RT325, Sneezles61
08 Jun 2023 13:31 #2
