My kickstart lever won't fit onto my spindle all the way
  • Jogar
  • Jogar's Avatar Topic Author
Here is a picture without the lever on
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
06 Apr 2023 22:41 #11
Hmm, ok thanks. In "my opinion" its the wrong shaft [or wrong case] wrong shaft i'd say. Should be able to see the splines finish & the start of the shaft for the seal to--seal. Think 360 case is wider in the cluch area for the slightly wider clutch basket than a 250, & wider at the shaft with longer shaft, so that takes me back to--[it has a 250 shaft fitted]. I might regret saying all that but happy to be corrected. I'll go & measure my DT1 case then 360 at the clutch area.
Last edit: 07 Apr 2023 00:32 by RT325.
06 Apr 2023 23:22 #12
Ok i'm talking rubbish above. Both mine measure eyeballing 65mm from case to taking eyeball straight down over the cover in clutch area. So i've probably got a 250 shaft in my 360 as is very short. My 250 motor has a full kick boss engagement & can just see splines behind it. & its quite a wide kick boss.
 Think i'll give up as i don't know any more & getting confused.
Last edit: 07 Apr 2023 00:35 by RT325.
06 Apr 2023 23:37 #13
The shaft on my '71 RT1B extends 17mm. The '73 RT3 extends 24mm.
The shafts are different.
The following user(s) Liked this Post: RT325, LETSJET, HouseofEnduro, Jogar
Last edit: 07 Apr 2023 06:38 by 1971DT250.
07 Apr 2023 06:37 #14
