Not Quite a Newbie - CT3 175
Replied by AirborneSilva on topic Not Quite a Newbie - CT3 175
Pull the cylinder and remove the piston then pull up lightly on the rod, if there's any movement up and down then yep your big end bearing is gone. A little side to side is normal.
24 Mar 2023 01:53 #21
Replied by Dennis D on topic Not Quite a Newbie - CT3 175
First thing I would do is pull the mag cover and turn the motor with the flywheel and see if it feels rough. If not, I would pull the clutch cover and access the kick idler gear and have a look at the roller bearing behind it and see if it is still intact.
25 Mar 2023 08:25 #22
