DT2 locating damper
  • Stevvo
  • Stevvo's Avatar Topic Author
DT2 locating damper was created by Stevvo
Hi, Im missing the fuel tank locating damper, 214-24184-00, that the rear of the tank sits on. Could somebody please measure the height of the tab on the tank that the rubber hold down band secures? Height from frame rails to tab please....
17 Mar 2023 08:16 #1
Replied by Brzn on topic DT2 locating damper
Looks like 1.25"
KDI Reproductions sells the piece
www.kdirepros.com/Fuel-Tank-Damper-p/214-24184-00-00.htm
The following user(s) Liked this Post: MarkT, SKYDANCER46, Stevvo
17 Mar 2023 09:05 #2
  • Stevvo
Replied by Stevvo on topic DT2 locating damper
Thanks for that, wont need to try and make one after all then!
18 Mar 2023 02:56 #3
Replied by OkieDeric on topic DT2 locating damper
On my DT3 it is held in place with zipties through the holes going around the frame.  Unsure if the bands are original.  On my dads DT2 it was completely missing and the tank only had the foam under it.  We bought the KDI one and used zip ties.
01 Jun 2023 10:10 #4
Replied by Swoop56 on topic DT2 locating damper
There is a stud located on the underside of the frame which the two looped ends of the rubber strap
slip over . The rubber strap fits other model bikes too , so one strap can mimic various strap lengths as required .
02 Jun 2023 17:09 #5
