Yamaha mx 360/500 tank
- EM ONE
Yamaha mx 360/500 tank was created by EM ONE
Ive aqquired a Yamaha MX 360/500 tank,to fit on my standard Rt3 frame it will have to be modified,has any one any experience of this.Also,id like to fit a metal screw type petrol cap,rather than the plastic ones they had originally,anybody know any alternatives
09 Mar 2023 11:57
Replied by RT325 on topic Yamaha mx 360/500 tank
Without having directly done it i 'think' the tank will sit on the frame tubes that head down each side at the rear. Correct me if wrong but they're mounted by one bolt at the rear.
09 Mar 2023 15:47
- EM ONE
Replied by EM ONE on topic Yamaha mx 360/500 tank
The tank fits over the frame rails,but then slides forward on the bump stops,when its fully located into the frame mounts the top yoke hits the upper rim of the tank,and like you say to the rear of the tank its mounted with a single bolt.I think this calls for some pictures,any ldeas on the tank cap
10 Mar 2023 00:40
- Eveready
Replied by Eveready on topic Yamaha mx 360/500 tank
I just finished putting a MX tank on a RT3, it fit good just had to make brace to bolt it down in the rear.
13 Mar 2023 14:52
- EM ONE
Same colour tank as my own,and it also doesnt fit at the rear.Also my tank is slidding too far fprward,and when the bars are turned the top yoke hits the tank,do you have the same problem
20 Mar 2023 13:19
- EM ONE
As you can see the top yoke hits the the neck of the tank,all i can do is put spacers under the top yoke.Has anybody done this before,i thought 360 MX frames were identical to 360 RTs,or do they have different yokes
23 Mar 2023 12:16
- Sneezles61
Replied by Sneezles61 on topic Yamaha mx 360/500 tank
I don’t know about the yoke sizes, but can you lift up yer tank by the seat a little bit? Maybe it’s too tight or needs something to elevate that connection point… I know mine was close or an RT..
Sneezles61
Sneezles61
23 Mar 2023 14:07
- EM ONE
By lifting it at the rear doesnt make much difference.If the tank with rubbers is pushed all the way into the slots in the frame,moving it at the rear puts it out of line with the rest of the bike also
23 Mar 2023 14:58
- EM ONE
Thats with the spacer in place,still very close,and its pushed as far forward as possible..This could be an SC500 tank,or are 360/250/500 tanks identical,alli can think is that the mx tanks were liifted higher to accomodate the expansion chamber.
- yamayeeha
Replied by yamayeeha on topic Yamaha mx 360/500 tank
The tank that will fit is the 1972 RT2mx(black stripe) and DT2mx(red stripe) as in the photo above that does fit.
The 1973 MX250(yellow stripe), mx 360(red stripe) and sc500(black stripe) are a different frame, and different tank -although look similar in a photo.
25 Mar 2023 15:25
