oil pump hose clamps--clips
  • maxx2395
  • maxx2395's Avatar Topic Author
oil pump hose clamps--clips was created by maxx2395
HI Everyone
Has anyone attatched the feed line for the oil pump and used
the clamps / clips part number 214-13164-00 / 9048802033,
I am trying to figure out how to use them, do I crimp them ?
Any help would be appreciated.
ED . . . . . .
31 Jan 2023 13:04 #1
Replied by Pete-RT1 on topic oil pump hose clamps--clips
I’ve replaced the hose on a couple of my bikes and reused the clips.
I slid them down the original hose then removed the hose and slid the clip off.
Refitting is the reverse.
They aren’t crimped.
Yamaha CT3 (in bits)
31 Jan 2023 14:09 #2
Replied by Pedalcrazy on topic oil pump hose clamps--clips
They are just spring steel and slide them on like Pete-RT1 suggests. I've used a small pick or finger nail to get them started when removing them.
31 Jan 2023 14:27 #3
Replied by 1971DT250 on topic oil pump hose clamps--clips
I found that it helps if you slip a fingernail under the edge and try to gently unwind it while pushing it off or on.
31 Jan 2023 15:18 #4
Replied by Gr8uncleal on topic oil pump hose clamps--clips
As an aside, original parts were black, but the ones sold by Yamaha now are plated in something silver - nickel, zinc maybe. This might be important for some folks.
01 Feb 2023 00:10 #5
Replied by msavitt on topic oil pump hose clamps--clips
these clamps are terrific when used with the yamaha hose which is pretty cheap on Partzilla. I found it helpful to put a drop of oil on hose where clamp will sit and to apply a bit of tension to hose which makes clamp slide over easier without risk of nicking hose
01 Feb 2023 08:13 #6
  • maxx2395
Replied by maxx2395 on topic oil pump hose clamps--clips
Hello everyone
Wanted to thanks everyone for the helpful replys, I am using the
Yamaha hose, Worked like a charm.
ED . . . . .
PS: sorry for the slow response, life gets in the way.
The following user(s) Liked this Post: MarkT, msavitt
07 Feb 2023 14:33 #7
