1/2 inch Gray Tube /Sheath on Some Wires
- nhsteve
1/2 inch Gray Tube /Sheath on Some Wires was created by nhsteve
Interesting.
Straight up answer: I don't know.
Possibly something added at the factory to assist with hooking things up? I seem to recall similar bits of tubing on other leads on a few other bikes I've worked on.
16 Jan 2023 08:38
- Tom P
Replied by Tom P on topic 1/2 inch Gray Tube /Sheath on Some Wires
I remember seeing that as well. NHSTEVE is probably correct, just helped in assembly. Like many of us use tape to mark wires we disconnect.
16 Jan 2023 08:48
- Sneezles61
Replied by Sneezles61 on topic 1/2 inch Gray Tube /Sheath on Some Wires
I wonder if it isn’t extra insulation were it could rub…
Black is a ground and doesn’t worry…
Sneezles61
Sneezles61
16 Jan 2023 15:19
Replied by Gr8uncleal on topic 1/2 inch Gray Tube /Sheath on Some Wires
I've also seen those small "sleeves" on indicator wires in dark green and dark brown/chocolate, so more than likely something to assist with wiring the bike up.
16 Jan 2023 23:51
- msavitt
Replied by msavitt on topic 1/2 inch Gray Tube /Sheath on Some Wires
left vs. right identification?
18 Jan 2023 09:26
"left vs. right identification?"
Sorry - yes, that is what I was trying to say. Don't know what the grey sleeve signifies, though.
18 Jan 2023 09:33
- msavitt
I am a moron, you got it right Al, I didn't see your post
19 Jan 2023 03:53
