Excessive play in rear hub? Pic
  • bhsdriller
  • bhsdriller's Avatar Topic Author
Excessive play in rear hub? Pic was created by bhsdriller
Going through this bike and taking the chain and rear tire off I noticed a lot of side to side movement in between whatever the sprocket is bolted to and the hub.  No movement forward/back along the sprocket axis but where you can see the gap there's side to side play.
Is this normal, can I fix it, do I need to start sourcing a new back wheel?
I searched parts diagrams and they show a damper but other than that there isn't much info when searching it.
11 Oct 2022 07:56 #1
Replied by AirborneSilva on topic Excessive play in rear hub? Pic
Knowing what bike would help others to help you...
11 Oct 2022 09:22 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Excessive play in rear hub? Pic
CT2?
Last edit: 11 Oct 2022 09:28 by Gr8uncleal.
11 Oct 2022 09:27 #3
Replied by MarkT on topic Excessive play in rear hub? Pic
Is the large snap ring still there?
11 Oct 2022 09:36 #4
Replied by mx360guy on topic Excessive play in rear hub? Pic
Hi B,
I am currently experiencing the same thing on my CT1C. I was lucky enough to find a NOS cush hub assembly. I also put a new big cir clip on it also and it really helped. It is better than it was but still has a little bit of movement. I have read that some side play is normal but back and forth is so not good.
Disclaimer: I am not a mechanic but just expressing my experience with this issue.
The great thing about this forum is the 2nd and 3rd opinions, agreements and disagreements.
You are bound to get a enough information to make a good decision about what you want to do.
Best forum ever.
11 Oct 2022 09:40 #5
Also the MX wheels of the same era have the sprockets mounted directly to the hubs so that may be an option.
11 Oct 2022 09:41 #6
  • Gr8uncleal
Re the big circlip/snap ring, I think that Enduronut posted some time ago about the right and wrong way to fit these (I think that one side may have a bevelled edge). However, me being me, I can't remember which was the right way!
Please forgive me if I imagined all of the above!
11 Oct 2022 09:51 #7
Sharp edge would go out.
11 Oct 2022 10:08 #8
I also moved the clip around 180 from the its original location and it seemed to tighten it up even more. I think the aluminum against the steel snap ring may wear a bit in places on the hub. Good to know about the beveled edge. Need to check that..
11 Oct 2022 10:13 #9
  • bhsdriller
Replied by bhsdriller on topic Excessive play in rear hub? Pic
Sorry yes it is a CT2.  I can see the large snap ring it is still there.
Bike is a new project and only thing left is a new rear tire to take a test ride and noticed this.  Also the missing shock bolt
11 Oct 2022 10:35 #10
