OIl pump drive shaft lube
  • gvthnks
  • gvthnks's Avatar Topic Author
OIl pump drive shaft lube was created by gvthnks
Perhaps a silly question, but how is the oil pump driveshaft lubricated on a DT3?
There's a seal seperating the pump from crank case lube, so is it lubed by 2 stroke oil?
30 Sep 2022 17:38 #1
Replied by MarkT on topic OIl pump drive shaft lube
Yes.
30 Sep 2022 18:36 #2
  • gvthnks
Replied by gvthnks on topic OIl pump drive shaft lube
Just checking. Thanks
30 Sep 2022 19:00 #3
