Poor running at part throttle w/video
- AirborneSilva
Replied by AirborneSilva on topic Poor running at part throttle w/video
RT325 thanks for the suggestion, sleep well my friend!
04 Sep 2022 09:35
#21
Replied by MarkT on topic Poor running at part throttle w/video
... have to darn near screw the idle screw all the way in to get it to idle at about 1350 RPM...
I'd go up to at least a 35 pilot.
04 Sep 2022 09:54
#22
- AirborneSilva
Thank you Mark, I'll give that a try then..
04 Sep 2022 10:56
#23
- RacerClam
Replied by RacerClam on topic Poor running at part throttle w/video
Mark this carb has a UFO in it and a 35 pilot will make it waaaay too rich , the ufo causes a stronger and soone pull of the needle jet . Tony if your aie screw wont make a difference at 2 or so turns out a smaller pilot would be better maybe a 17.5. The crackle I hear at your low ttrottle position probabley would like the needle dropped a notch. OR cut the arch a half mm . But still hearing the full range of acceleration would be great ,
racerclam
04 Sep 2022 12:34
#24
Didn't know about the UFO.
04 Sep 2022 12:59
#25
- Sneezles61
Replied by Sneezles61 on topic Poor running at part throttle w/video
OK, I’ll bite… what is UFO with the carb?
Sneezles61
Sneezles61
04 Sep 2022 13:55
#26
An insert that goes in bottom of slide. Been around for many years. Some swear by them.
thunderproducts.com/product/ufo-ultimate-flow-optimizer/
- AirborneSilva
Rich, the 20 I put back in it smoothed out the part throttle where as the 15 gave it that crackle. I can get a 17.5 Tuesday and give that a go. Now full throttle is doing it, not quite as bad though. I can drop the needle so it's on the second position from the top if you think that would help. I will say I did drop it to the second from the bottom which made no difference. I currently have a 200 main jet in it, which ran fine when I first put it in but the bike decided it didn't like it. The next smallest jet I have is a 350.
EDIT: Oh and sorry all, I completely forgot the UFO. Also, what do you mean by the arch Rich?
- jcarr
Replied by jcarr on topic Poor running at part throttle w/video
Jetting can be a chase, changing one jet effects another, a rich idle jet could be covering up a lean needle jet or slide cutaway and so on.If you don't already have it, here's a link for the Mikuni tuning manual.And go with what ever Rich (racerclam) says.Good luck,
wahlracing.com/wp-content/uploads/2017/0...und-slide-manual.pdf
richstayloredporting.com/carb.html
- AirborneSilva
Thanks Jcarr, yeah this is beginning to be a headache! I'll take a Holley carb tuning anytime... Your link didn't work.
04 Sep 2022 14:34
#30
