Shifter shaft seal
- dubepj
Shifter shaft seal was created by dubepj
Fixing a 1973 RT3. Just waiting on a carb gasket and a Petcock rubber. Put new oil in tranny and noticed a small leak at the shifter shaft seal. Can I replace the seal without splitting the engine. Sometimes you can pull old seal by screwing a screw and pulling it out?? Any advice is well come.
07 Aug 2022 11:18
- darinm
Replied by darinm on topic Shifter shaft seal
Yup it's just like you say, you can pull it out with a screw, pick, or modified screwdriver.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
07 Aug 2022 11:38
- dubepj
Replied by dubepj on topic Shifter shaft seal
Thanks Darinm. Now I'll see if My Local Yamaha store has one. Should I drain oil first or can I just lean bike over??
07 Aug 2022 14:13
- AirborneSilva
Replied by AirborneSilva on topic Shifter shaft seal
I changed mine on my DT2 not long ago, was really easy and didn't have to lean bike over. Make sure you clean you seat really well.
07 Aug 2022 16:13
- darinm
I just lean em over
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
07 Aug 2022 16:30
- Le7316
Replied by Le7316 on topic Shifter shaft seal
Instead of shifter shaft seal ...im replacing my countershaft seal of the 72 LT2 hehehe.
18 Aug 2022 12:07
- AirborneSilva
Might as well replace the shifter shaft seal while you're there. Just a thought...
18 Aug 2022 12:16
- Le7316
Previous owner already replaced all 3 but i guess he just didn't do a really good job on Countershaft one. I've checked other seals. Good to go.
18 Aug 2022 12:32
- AirborneSilva
Well that's a good reason to not change it
18 Aug 2022 13:28
