Front turn signal wire grommets
  • Dennis D
  • Dennis D's Avatar Topic Author
Front turn signal wire grommets was created by Dennis D
I did a search and haven't had any luck finding a source for these. Also
looked at McMaster Carr to find a generic grommet and didn't have any
luck finding a correct size. Several post about these, did anyone have any
luck finding a replacement? Thanks, D
02 Aug 2022 10:20 #1
Replied by mike8162 on topic Front turn signal wire grommets
I had a set of fronts rechromed for my DT3. The grommets were toast so I used neutral wire isolators from HVC Cycle. (#HVC200116) If I recall I had to drill the hole slightly larger, 6mm I think. They don't have the little stem on them but worked like a charm.
Cheers
02 Aug 2022 17:08 #2
Replied by Ht1kid on topic Front turn signal wire grommets
Bought this at harbor freight and worked on my Ct1c front blinkers
02 Aug 2022 18:28 #3
Replied by Gr8uncleal on topic Front turn signal wire grommets
If there was enough demand, then I expect that Sumo Rubber (in the UK) might look into having them made.
03 Aug 2022 00:16 #4
Replied by Pete-RT1 on topic Front turn signal wire grommets
Grommets are available without the sleeve, I've used them on several of my bikes without the need to modify the indicator.
I'm away at the moment, will have a look when I get back at the weekend.
Yamaha CT3 (in bits)
03 Aug 2022 00:58 #5
  • Dennis D
Replied by Dennis D on topic Front turn signal wire grommets
Thanks, already had the housings chromed and would like to
find something that fits the current hole size. D
03 Aug 2022 12:40 #6
