RT3 Kickstarter assembly.
  • carter6787
  • carter6787's Avatar Topic Author
RT3 Kickstarter assembly. was created by carter6787
I am about to re install my RT3 kickstart assembly back into the crankcase but I am not sure if I am missing a part.Is there a cover plate before the return spring?My instruction manual is for  a DT1 which shows one (part 3 in the diagram) but did Yamaha remove the spring cover on the later RT3 models?     I am about to re install my RT3 kickstart assembly back into the crankcase but I am not sure if I am missing a part.Is there a cover plate before the return spring?My instruction manual is for  a DT1 which shows one (part 3 in the diagram) but did Yamaha remove the spring cover on the later RT3 models?
03 Jun 2022 22:49 #1
Replied by Swoop56 on topic RT3 Kickstarter assembly.
My RT2 manual shows the assy as you have it . No cover plate #3 as on DT1 .
The following user(s) Liked this Post: carter6787
04 Jun 2022 00:58 #2
  • carter6787
Replied by carter6787 on topic RT3 Kickstarter assembly.
Thanks, I thought so but just needed to be sure.
05 Jun 2022 01:15 #3
