Looking for a start- RT2 360
Replied by DEET on topic Looking for a start- RT2 360
Just to clarify…..
The nut holding the flywheel on is regular right hand thread.
The flywheel puller that screws into the flywheel is reverse or LEFT hand threads.
The following user(s) Liked this Post: MarkT, Ht1kid, Enduro nut, Brzn
18 Feb 2022 05:37 #11
Replied by Brzn on topic Looking for a start- RT2 360
Rattle gun? Air or electric?
18 Feb 2022 05:51 #12
Replied by darinm on topic Looking for a start- RT2 360
I was able to get away with an electric on my CT2. Works pretty well for most things actually, they have come a long ways in the last few years.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
18 Feb 2022 08:23 #13
Replied by Enduro nut on topic Looking for a start- RT2 360
The correct flywheel puller is a must. As for the nut i just use an electric impact gun and hold the flywheel with my hand after soaking it with some penetrating oil. Those points look absolutely disgusting! if it was me i would replace them. Your coil looks like a cheapy which might give you trouble but for now id focus on cleaning up the flywheel, stator and points.
18 Feb 2022 08:47 #14
  • Isaac-RT2
  • Isaac-RT2's Avatar Topic Author
Replied by Isaac-RT2 on topic Looking for a start- RT2 360
Thanks for the advice, with a flywheel holder and puller it came off easily! As was expected, everything was corroded as hell. So far, I’ve done my best to clean all surfaces but there is major damage to the flywheel ‘cam shaft’ and condenser. After vigorously cleaning the shaft (haha), I’ve noticed some serious pitting. Seems like this pitting will make quick work on the points/cam contact thing (don’t know the term). I’ve not been able to find a new replacement flywheel in my budget so I’m gonna stick with it for now. Are there any tech tips of filling these pits or just replace the points when they wear out? On that note, I’m looking for new points and condenser. Any suggestions? I found this condenser on eBay that I’ll get unless there’s a better option. Does anyone have a good source for replacement points? Also, is this a cam cleaner and is it necessary? It looks pretty screwed and doubt it’s worth the effort to put back in. Thoughts?
As always, thanks for your help!
04 Mar 2022 16:42 #15
  • Isaac-RT2
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=392757591290&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by RT325 on topic Looking for a start- RT2 360
Lately i've started spinning my motors--100 & up to 360--with a drill & socket on the mag crank nut. Don't know why i never thought of it before. My drill does left hand --reverse-- & is a quite a grunty drill with speed/torque adjustment. So handy to just sit there & spin it up rather than kick kick. On the 360 i took both plug & blank off out to make it easier. Little 100 i started it up like that with the drill for bench testing & playing around. Had to be careful though as the torque just about screwed it out of my hand the first time on the 360 so was a two hand job.
05 Mar 2022 01:10 #17
Replied by hackman101 on topic Looking for a start- RT2 360
Just a note on what you referred to as the "cam cleaner" It I believe is a cam oiler, it is a felt like material that is to be soaked in oil but not dripping, so the points have lubrication in place at all times, well as long as there is oil in the felt.
1973 MX250
1964 Honda 50cc C110
1960s Yamaha 65cc scooter
05 Mar 2022 21:44 #18
