Is it the Boyseen reeds
  • mpritch41
  • mpritch41's Avatar Topic Author
Is it the Boyseen reeds was created by mpritch41
I have a 1972 Yamaha CT 2 that I race cross country. 4 years ago, I had a season where the bike would die in the middle of the race. My only modification was putting in Boyseen reeds.
I raced today and after a hard 45 min. Ride, it just died. Has spark, no vaccum on tank and I pulled the gas line off and it had free flow.
We, I had put the Boyseen reeds back in a few months ago.
Anyone have any experience or idea about what is happening or how to fix this other than to put the old metal reeds back in?
07 Jan 2022 16:58 #1
Replied by Tinkicker on topic Is it the Boyseen reeds
Try another ignition coil.
07 Jan 2022 17:06 #2
  • mpritch41
Replied by mpritch41 on topic Is it the Boyseen reeds
That's a thought, I failed to mention it cranked after a few minutes.
plug color was perfect and it was running top to bottom absolutely clean.
07 Jan 2022 17:16 #3
Replied by Bartman512 on topic Is it the Boyseen reeds
Sure it didn'tfoul a plug?
08 Jan 2022 07:13 #4
Replied by MarkT on topic Is it the Boyseen reeds
That's quite a coincidence.
I'm not a fan of Boyesen reeds for top end power but I don't know how they would cause an intermittent engine shut down.
08 Jan 2022 07:26 #5
  • mpritch41
Well...pulled the old one out ...looked great.
put new one in...went 50 feet and it died.
Did crank after a few min.
08 Jan 2022 10:14 #6
Replied by Ht1kid on topic Is it the Boyseen reeds
My guess is either a coil or condenser have had it happen to me turns out it was the condenser.
08 Jan 2022 10:26 #7
Replied by Makotosun on topic Is it the Boyseen reeds
I run Boyesen reeds in most of my bikes, and have never had an issue like you describe (or any issue for that matter.
08 Jan 2022 13:31 #8
Replied by RT325 on topic Is it the Boyseen reeds
Be the stator source coil faulty. I'm guessing its the plug secondary coil you replaced that made no difference. How does the source coil 'look'--not damaged? or come loose in the windings on its post. Of course i could be wrong--again.
09 Jan 2022 14:46 #9
I had the same problem on my Ct1c changed the coil still died my source coil looked and tested good so I changed the condenser and no more problems cheap fix too
09 Jan 2022 15:49 #10
