Dt2 forks on At1
  • userdakota
  • userdakota's Avatar Topic Author
Dt2 forks on At1 was created by userdakota
I'm sure this has been covered, but I cant uncover it. I would like to put the dt2 forks on a at1. My problem is what triples are used to be able to slide the fork tubes up without contacting the handle bars. Thanks
23 Dec 2021 19:12 #1
Replied by MarkT on topic Dt2 forks on At1
Not sure you can slide the tubes up very far before tire will hit at full compression...  Which is really, really bad.  I think most people just use the stock DT clamps.
23 Dec 2021 21:51 #2
Replied by RT325 on topic Dt2 forks on At1
Not a very good pic but i'm using DT250 forks from the first monoshock so about "78 at a guess & can slide the forks up. But as i think Mark said, got to be careful of the wheel touching the guard under fork compression if you slide them up too far. Forks are a bit heavier than AT1 forks so probably a trifle overdone. I also have forks from a "78 DT125 which i'll try on my AT1 1970 if they don't sell. Nice long travel & not heavy. Can slide them up too.
Dt125E 1978 Frame & swingarm plus front end forks & wheel. | Trade Me Motors
Last edit: 24 Dec 2021 01:56 by RT325.
24 Dec 2021 01:53 #3
Meant this pic for 250 forks
24 Dec 2021 01:55 #4
  • userdakota
Replied by userdakota on topic Dt2 forks on At1
Yes I agree, just need about a inch and a half maybe. This thing looks like a chopper. I have extended the swingarm 1 1/2 inch. Thinking I should go with 13 inch shocks. Any thoughts on this. Thanks
24 Dec 2021 07:21 #5
Replied by Capt.Dave on topic Dt2 forks on At1
Use the whole front end, you will need 13 1/2 shocks.
24 Dec 2021 08:47 #6
  • userdakota
Thank you Dave, I am using the complete forks with triple tree from a RT2, I have also installed a 21 inch front wheel. you say by using the 13 1/2 inch shocks you dont need to slide the fork tubes up the triple clamp? What shocks are folks using for this type of modification. Thanks everyone for the help.
Last edit: 24 Dec 2021 14:08 by userdakota. Reason: to give more info
24 Dec 2021 10:43 #7
Replied by DaveHunter on topic Dt2 forks on At1
78 DT 250 forks and triple on my CT
24 Dec 2021 17:00 #8
  • userdakota
Ok, now I see. I need the upper triple clamp that you have in order to slide the fork tubes up. I have the 72 clamps they dont have the handlebar kick back that yours has. Thank you for posting.
24 Dec 2021 18:23 #9
Replied by Makotosun on topic Dt2 forks on At1
A friend of mine put DT forks and a 21” front end on his AT1MX. He also added, if I remember correctly, 2” to his swing arm to allow for a larger rear tire to fit.
Last edit: 25 Dec 2021 04:18 by Makotosun.
25 Dec 2021 04:17 #10
