In search of a 72 DT2 oil tank assy
  • Bartman512
  • Bartman512's Avatar Topic Author
In search of a 72 DT2 oil tank assy was created by Bartman512
So far Ive bought 2 off ebay that are so far gone, dented and cracked it's not worth my time trying to fix.
03 Dec 2021 06:47 #1
Replied by Hooka-2 on topic In search of a 72 DT2 oil tank assy
Bartman512:
Are the ones that you bought the original color (pearl/yellow gold that looks orange) ? I'm looking for a piece that I can leave at my local paint shop to match the color. Doesn't have to be functional just needs to have a spot with good color. If you have one of that description what would you want for it? $$$$$
03 Dec 2021 10:58 #2
  • Bartman512
Replied by Bartman512 on topic In search of a 72 DT2 oil tank assy
The one i got that's half decent is stripped of paint and the sight glass is facing aft so not sure what yr or model it came off of., although it fits in my DT2 frame. Also has a leaking banjo fitting on the bottom for the oil to pump line.
04 Dec 2021 10:37 #3
Replied by Gr8uncleal on topic In search of a 72 DT2 oil tank assy
If it's got a banjo fitment, then I'd suggest it's for a DT1, as the DT2 onwards had the hose fitting over a connection like on the carb and fuel tap.
04 Dec 2021 12:08 #4
Replied by adguy2112 on topic In search of a 72 DT2 oil tank assy
   If the dents are near the oil fill tube I was able to get enough access by grinding off the back edge of the fill tube then prying out the flat back. I reinstalled then filled the edges with oil resistant JB weld.
05 Dec 2021 09:29 #5
