GAUGE RECONDITIONING (AT2)
Replied by MarkT on topic GAUGE RECONDITIONING (AT2)
Here's a link to one of the threads with a lot of good posts on gauges... includes the pictures of Devin's crimping tool.
yamaha-enduros.com/index.php/forums/how-...uge-restoration#2004
The following user(s) Liked this Post: RT1
29 Nov 2021 09:29
#11
- RT1
Replied by RT1 on topic GAUGE RECONDITIONING (AT2)
Thank you Mauser
More to come.
There'll be a period of down time while the bodies are out for re-chroming and the other odds 'n ends collected.
More to come.
'68 DT1, '71 RT1, '71 JT1 (x2), '72 AT2 (x2), '74 DT250A, '75 XS650, '54 BSA C11G, '70 Honda CT70, '73 Hodaka Combat Wombat, '05 Moto-Guzzi Breva, '15 Triumph Tiger, +++
"We are mere custodians of mechanical things. Our job it to care for them, improve them and pass them on to others.” - Peter Egan
06 Dec 2021 06:18
#12
- RT1
A bit more to show regarding my gauge reconditioning. Although I already successfully removed the tiny screw that holds on the trip meter reset knob for my reconditioning needs, I have additional gauges here and am continuing to push myself in dissecting, cleaning and reassembling the internals to an operative condition. I was fortunate with the unit I previously took apart. The next one was impossible to extract b/c the screw head was too corroded for a screwdriver to get a bite. Somewhere in my searching the threads on this subject I read a question concerning the drilling off of the screw head. In that thread it was kind of discouraged because an unskilled attempt could cause more problems. Remember - the knob has to come off to get the gauge disassembled which I learned earlier in this thread. And, I have not much to lose by trying because this is a spare. I will say that it's an operation that is not for the faint of heart and requires a gentle and patient approach. The pictures below will show my process.
The first steps were to drill off the screw head. There's no pics of the drilling. You simply need to be sure to use bits that aren't too big or you'll damage the surface on which the screw head tightens down inside of the knob. The bit shouldn't be any larger than the shaft of the screw and you need to patiently feel your placement of the tip of the bit so as to be centered in the screw head. I probably retracted the bit 3-4 times to be sure I was removing material and that it was in fact metal and not plastic from the knob. After I was somewhat confident that I drilled through the head, I use a slightly larger left hand bit believing it would snap the head off the screw as soon as it bit in... and I was right. Mind you, you operating on feel and evidence of your drilling... but you can't see a damn thing! The knob doesn't simply fall off. You need to test now and then by gently trying to pull it off.Once the knob was out of the way, I put the end of the trip meter "axle" shaft into mineral spirits (other solvents could be used) and let it soak for five days. Then I clamped on to the shaft with a small pair of vise-grips being careful to be sure that one jaw of the vice-grip was on the flat surface of the shaft to prevent rotation when extracting the stub of the screw. I used a bit of heat to help along any additional resistance that I could eliminate. A screw this small and rusted will be very brittle and easy to break off flush... and then you've got a whole new challenge! Once heated, I used a good set of my smaller pliers that have good gripping jaws, grabbed hold and started turning out. It cooperated from the first twist! I hope this is helpful to someone in the future faced with a similar issue.
Pics....
Pics....
- RT1
Remaining pics......
The following user(s) Liked this Post: Pedalcrazy, Top Jimmy, Sneezles61
10 Dec 2021 15:46
#14
- Sneezles61
Replied by Sneezles61 on topic GAUGE RECONDITIONING (AT2)
This appears a very quiet.. relaxed tinkering.. I'll need to look at my DT 250A's.. they are on the mount.. all wobble-y..
Thank you for sharing your hobby!
Sneezles61
Sneezles61
10 Dec 2021 19:52
#15
- RT1
For those that have interest I wanted to share the conclusion of my gauge reconditioning project.
I'm pleased with the outcome and that I challenged myself.
I have a several more of these gauges and there's a part of me that would like to recondition them as well but there's quite a bit of $$$ outlay for the supplies and the re-chroming and it's money better spent elsewhere.... even if I was to do it with an eye towards selling them. I'll probably just sell off the remaining gauges and parts when the AT2 is finished.
Pics of the conclusion follow.
The following user(s) Liked this Post: Bigdog302, Sneezles61
- RT1
- RT1
01 Feb 2022 11:31
#18
- RT1
The following user(s) Liked this Post: MarkT, Bigdog302, swm, Ht1kid, Quartermaster35, adguy2112
01 Feb 2022 11:32
#19
- Bigdog302
Replied by Bigdog302 on topic GAUGE RECONDITIONING (AT2)
Nicely Done!!
Dave
Jesus is Lord!
Dave
Jesus is Lord!
03 Feb 2022 14:07
#20
